07-18-2003 06:16 PM - edited 03-02-2019 08:57 AM
I needed to upgrade my 2 x MSFC2's to c6msfc2-dsv-mz.121-19.E1.bin from c6msfc2-is-mz.121-3a.E4.
I copied the new image to sup-slot0:, added the boot system variable and reset the MSFC's from CatOS - they booted the new image from sup-slot0: succesfully.
At this time, the Sup2's were running 6.3(1).
I then upgraded my CatOS to 7.6(1), and rebooted the switches. On both of the boxes, the MSFC booted the 'old' image which was still in bootflash instead of booting the new image from sup-slot0:
I thought this might be a timing issue as the new CatOS took some time to come on line, but even when I reset the MSFC's from CatOS, they still would not boot the sup-slot0: image.
Here's my boot system commands :-
boot system flash sup-slot0:c6msfc2-dsv-mz.121-19.E1.bin
boot system bootflash:c6msfc2-is-mz.121-3a.E4
Any ideas ?
Paul.
07-18-2003 06:22 PM
What bootloader image you do you have? We had some bugs in older boot ldr images. I suggest that you download 12.1(19)E1 bootloader image to the bootflash and point boot ldr variable to it.
07-19-2003 04:45 AM
I am running boot version c6msfc2-boot-mz.121-3a.E4
I will try downloading a later boot image & give that a go.
Thanks for the info.
Paul.
07-19-2003 06:33 PM
Let me know how it goes. If it does not work, try the following.
** Since you have a MSFC2, you do not need a boot image. You can delete the boot image and fit the regualar IOS image. If you have a MSFC(1), boot image is a mandatory requirement.
OR
**Get 32MB bootflash upgrade kit from Cisco. I believe this is a free upgrade
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_14703.htm
07-21-2003 04:27 AM
Before I go ahead and remove the boot image to free up enough space to get the new IOS on my MSFC2, have you got a URL explaining that this is ok please ?
I am nervous of removing the boot image since the documentation I have says that this will render my MSFC2 inoperable & require a return to Cisco.
TIA,
Paul.
07-21-2003 04:55 AM
I could not find any documentation for MSFC2. here is an output from my lab switch..i deleted the boot
image and reloaded the MSFC2. It booted just finerh-animal-122a-1-core#dir bootflash:
Directory of bootflash:/
1 -rw- 1785908 May 26 2003 17:36:13 c6msfc2-boot-mz.121-13.E6.bin
2 -rw- 13087784 May 26 2003 17:36:24 c6msfc2-psv-mz.121-13.E6.bin
3 -rw- 511265 Jul 03 2003 15:47:17 crashinfo_20020524-095941-12_0
31981568 bytes total (16596224 bytes free)
rh-animal-122a-1-core#delete bootflash:c6msfc2-boot-mz.121-13.E6.bin
Delete filename [c6msfc2-boot-mz.121-13.E6.bin]?
Delete bootflash:c6msfc2-boot-mz.121-13.E6.bin? [confirm]
rh-animal-122a-1-core#squeeze bootflash:
All deleted files will be removed. Continue? [confirm]
Squeeze operation may take a while. Continue? [confirm]
Squeeze of bootflash complete
rh-animal-122a-1-core#sh run
Building configuration...
Current configuration : 6399 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname rh-animal-122a-1-core
boot system flash sup-disk0:c6msfc2-jk2o3sv-mz.121-13.E4
boot bootldr bootflash:c6msfc2-boot-mz.121-13.E6.bin
clock timezone PDT -7
ip subnet-zero
ip domain-list net.wisc.edu
no ip domain-lookup
ip domain-name net.wisc.edu
ip name-server 144.92.254.254
ip name-server 128.104.254.254
rh-animal-122a-1-core#conf t
Enter configuration commands, one per line. End with CNTL/Z.
rh-animal-122a-1-core(config)#$tldr bootflash:c6msfc2-boot-mz.121-13.E6.bin
rh-animal-122a-1-core(config)#$sup-disk0:c6msfc2-jk2o3sv-mz.121-13.E4
rh-animal-122a-1-core(config)#boot sy
rh-animal-122a-1-core(config)#$ flash bootflash:c6msfc2-psv-mz.121-13.E6.bin
rh-animal-122a-1-core(config)#end
rh-animal-122a-1-core#wr
1w3d: %SYS-5-CONFIG_I: Configured from console by console
[OK]
rh-animal-122a-1-core#sh boot
BOOT variable = bootflash:c6msfc2-psv-mz.121-13.E6.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable =
rh-animal-122a-1-core#reload
Proceed with reload? [confirm]
1w3d: %SYS-5-RELOAD: Reload requested
1w3d: %OSPF-5-ADJCHG: Process 10, Nbr 50.50.50.1 on Vlan1577 from FULL to DOWN,
Neighbor Down: Interface down or detached
1w3d: %OSPF-5-ADJCHG: Process 10, Nbr 50.50.50.1 on Vlan1502 from FULL to DOWN,
1w3d: %OSPF-5-ADJCHG: Process 10, Nbr 50.50.50.1 on Vlan1501 from FULL to DOWN,
System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2002 by cisco Systems, Inc.
Cat6k-MSFC2 platform with 262144 Kbytes of main memory
Self decompressing the image :
[OK]
RP: Currently running ROMMON from S (Gold) region
loadprog: bad file magic number: 0x0
boot: cannot load "cisco2-Cat6k-MSFC2"
[OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) MSFC2 Software (C6MSFC2-PSV-M), Version 12.1(13)E6, EARLY DEPLOYMENT
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 17-Apr-03 19:46 by hqluong
Image text-base: 0x40008C00, data-base: 0x4187E000
cisco Cat6k-MSFC2 (R7000) processor with 229376K/32768K bytes of memory.
Processor board ID SAL071004NS
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
509K bytes of non-volatile configuration memory.
07-21-2003 07:18 AM
Thanks again for your help, that works.
