Webcast-Catalyst9k
MTU problem
Hi team.
I´m having some problems in a Bridging network. I have a Cisco 7513 then ATM cloud and then a Catalyst 2924 whit a STM-1 ATM, doing binding between PVC and VLAN.
The problem is i can´t do ping greater than 1484 b.
In the 7513 i have already configured RBE, whit the ip in the same subinterface atm ( Not unnumbered ). And the MTU is configured in 1500
I hear any comments.
Thks all.
Pablo.
1 REPLY
Silver
Re: MTU problem
Pablo,
Is there shaping configured on the ATM trasnport. This (dropping) can happen if you are exceeding an ingress UPC (Usage Parameter Control) on the ATM switch. If shaping is configured best bet for you might be to match thier SCR/PCR/MBS configuration on your PVCs.
Hope this helps,
Don
95
