MTU Problem
Hi team.
I´m having some problems in a Bridging network. I have a Cisco 7513 then ATM cloud and then a Catalyst 2924 whit a STM-1 ATM, doing binding between PVC and VLAN.
The problem is i can´t do ping greater than 1484 b.
In the 7513 i have already configured RBE, whit the ip in the Loopback interface ( IP unnumbered ). And the MTU is configured in 1500 in the subint ATM
I did some test´s and the router is doing something very strange.
I had configured a PVC whit RBE and it didn´t work, but if i create a new interface and paste the pvc in this inteface works fine. If i delete the PVC and create again it didn´t work. And the again the same create a new interface and works again etc...
I think is a Bug but.........
I hear any comments.
Thks all.
Pablo.
Re: MTU Problem
Certainly appears to be bug related.
http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
Insert your software version into this tool and check your results. If you are unsuccessful contact the Technical Assistance Center; though expect a request for code upgrade early in the process.
Re: MTU Problem
Remove "mtu 1500" from the ATM interface and try adding " ip mtu 1500 " and see whether it works.
86
