Multi chasis ML PPP
Hi everybody,
On 2 access servers I configured Stack group binding protocol to operate MMPPP. If I use the same username for 2 connection , there is no problem. I can see MMPPP bundle is created on only first access server. Client operates perfectly.
But if I use a username for the first connection and an other username for the second connection , it is not operating. I can see the bundle is created on the first access server but I cann't ping from the client until the second connection becomes down. I tried 3 types of bundle name construction methods( username , end station , both ). This didn't solve my problem. The bundle name in this case is the same but it doesn't operate.
When using SGBP , do we need to use the same username for the 2 connections?
Or there is anybody solved this issue?
I am using 12.07T Enterprise Plus IOS.
Thanks everybody
1 REPLY
Re: Multi chasis ML PPP
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
128
