Multi E3 over PA-POS-OC3(SMI) ... is possible ???
I would like know if is possible use a PA-POS-OC3SMI (155 Mbps) for collect the traffic from two E3 (34 Mbps).
Of course, if is possible, I would like know how can I must configure the PA-POS-0CE3SMI for routing over two links at 34Mbps.
I show an example of my reality:
E3--------------- ---------
| ADM |---------------------| ADM | ---- PA-POS-OC3SMI
Thanks in advances,
Christian (Italy)
1 REPLY
Re: Multi E3 over PA-POS-OC3(SMI) ... is possible ???
Hi Christian -
The PA-POS-OC3xxx port adapters are for "concatenated" OC3, which means that there is one STS-3 payload per SONET frame. It's not possible to MUX 3 STS-1 streams and terminate them into this port adapter.
I'm not sure what the SDH terminology is for this, but the principle is the same.
Clay
92
