Multi layer switching and ACL's
Can anyone direct me to documentation on MLS and using both inbound and outbound acl's.
Any known problems utilizing both inbound and outbound acl with MLS?
thank you!
Re: Multi layer switching and ACL's
I'm assuming you are asking this for a CAT6k. ACLs are implemented in hardware and should not have performance issues. See if the following document helps
http://www.cisco.com/warp/customer/cc/pd/si/casi/ca6000/tech/65acl_wp.pdf
Thank you for the links
Hi Prkrishn
What If I wanted to apply MLS to a 5500 with NFFC 2...I read somewhere that there wasa possible security risk with the extended ACL's ...
eg if snmp is allowed but icmp is not ... and the first flow between two workstns is snmp, then an mls entry is made ... but if the second flow is icmp and that is blocked by the acl ... would the switch forward it? Is deny traffic "always" handled by the MLS-RP?
the article I read also mentioned that this was a Cisco bug and it was solved with the 6000 series using a PFC..
Any comments on this would be highly appreciated
129
