04-08-2003 07:53 AM - edited 03-02-2019 06:30 AM
dear engineers,
i have a 4507 r switch installed as backbone to my nework. i wish to implement MLS (multilayer layer switching) on this. but no supported commands found on the switch. one of my cisco trainer were saying MLS is already implemented on the 4507 r. no more configuration is needed.
is it true.. please advice me.
regards
kondela
04-08-2003 09:35 AM
Hi sagia
i'm not sure if mls is enabled by defualt on your switch/R
but you can make sure and test your mls cache with the command:
sh mls enty *
see if there is any entry created in your cache
i hope this helps
Best Regards
farshid
04-08-2003 05:50 PM
The 4507 may just use CEF rather than MLS. This is the case for the Cat6500 SUP2 and SUP720 modules.
04-10-2003 06:10 PM
450x with Sup3/4 uses CEF based forwarding by default
