multicast and vlans
hello,
If i have multicast clients on differents vlans,
all of them are connected to a router by a dot1Q trunk ,will the router send a copy of each frame
in each vlan? is it able to send only one frame on the trunk? and the switch will send the frames on interested ports? how is called this feature and how can i conf it on routers and switch?
a link would be useful
Thanks, regards
1 REPLY
Re: multicast and vlans
will the router send a copy of each frame in each vlan?
yes
no
the switch will send frames on interested ports?
yes, enable igmp, and i'm assuming you have a router to route between the vlans that supports multicast.
to configure
globally ip multicast
per interface
ip pim sparse-dense
additionally, you should probably configure an rp, with one router a static rp should be fine, and I believe that on most switches igmp is enabled by default.
164
