Webcast-Catalyst9k
multicast config problem
Scenario:
I have a router that is configured for multicast (pim sparse mode). Behind this router is a host that does not understand multicasts, only uni and broadcasts.
Question:
How do I configure the router so that the host can join the multicast group?
Thanks, Meg
1 ACCEPTED SOLUTION
Re: multicast config problem
Pls try ' ip multicast helper-map ......', look into the URL for details.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcpt3/1cfmulti.htm#18662
Rgds / Tao
Green
If the device doesn't understand multicast, then you'll need some kind of conversion upstream.
Is it possible that the transitting device does "smallcasting" (unicast) ala the Cisco IPTV?
Can it be done with DVMRP?
Scott
Rgds / Tao
90
