Webcast-Catalyst9k
wkw
Multicast error problem
One of our Cat5513 has been displaying a lot of the error message below:
%SYS-4-P2_WARN: 8/Invalid traffic from multicast source address 01:00:5a:52:4c:4d on port 8/58
The frequency of this is quite disturbing. Any idea what this error is about? Module no.8 is our Gigabit Ethernet WS-X5410. Can that multicast address be mapped to an IP address or unicast mac-addresS? How can i go about resolving this?
thanks
woon
Purple
Re: Multicast error problem
Hi Woon,
There is a list of multicast address fixes at this location:
http://www.cavebear.com/CaveBear/Ethernet/multicast.html
However, I don't see an assigned address prefix of 01-00-5A. What devices have you got connected to port 8/58. You might have to trace through all your switches to find out which port the offending device is connected to.
Hope that helps.
Paresh
wkw
Thanks for the reply Paresh. Port 8/58 is a virtual port of some kind since there are nowhere near 58 ports on any of Cisco's modules! I suspect is the backplane connecting Module no.8 to the Cat5513. Unfortunately I'm not quite sure how to go about tracing this mac-address.. show cam doesnt seem to reveal .. to go through all the switches would be near impossible since we have more than 100+ switches in our university. Yeah, the assigned address prefix of 01-00-5A is dodgy.. i was thinking of a map for those assigned address prefixes of 01-00-5e but I've never seen 5A before..I'm assuming that's the layer-2 multicast address, which means there's an equivalent layer-2 unicast address, although I do not know how to link them together
The 8/58 is most likely a reference to a port channel. Issue the show port command to verify this.
If this channel is a vlan trunk, you might still be left with quite some seaching but knowing this should limit the possible origin substantially.
It could be anything from a load balancing server farm to a network gaming protocol. Happy hunting!
Leo
I have the same problem, but my switch is directly connected to router 7200VXR-NPEG1, with optic fiber wire.
so there is no posibility that MAC 01:00:5a:52:4c:4d came from this router because the router MAC in this interface is 001e.1426.bc1a.
so how can be this possibly? how I can stop multicast in switch / routers interfaces at the edge?
(switch 4506) - (router7200VXR-NPEG1)
look up the log:
Feb  8 05:37:56: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 4 times)Packet received with invalid source MAC address (01:00:5A:52:4C:4D) on port Gi1/2 in vlan 1
sw_4500#sh cdp ne
rtpeclo01           Gig 1/2               150             R       7206VXR   Gig 0/2
rt_7200#sh run int gi 0/2
interface GigabitEthernet0/2
ip address 10.100.2.1 255.255.255.0
media-type gbic
end
rt_7200#sh arp | in 10.100.2.1
Internet  10.100.2.1              -   001e.1426.bc1a  ARPA   GigabitEthernet0/2
sw_4500#sh run int gi 1/2
interface GigabitEthernet1/2
switchport mode trunk
end
Purple
you get this message because this mac address has the I/G bit set so it is a group address and can never be a source address but it could be a destination address. the multicast L2 range for mapping L3 multicast is 01-00-5E  not 5A so it is
either a malformed address due to a faulty ethernet controller or someone sending forged mac addresses.
Alain
620
