Community Member
Multicast Output explanation
Hello
Im not convinced with the following 'sh ip mroute ' output. The Flags CJT are missing eventhough there are directly connected members s . But evrythng seems to be working fine. Also what is 6d14h/stopped,
ldn-lw4-r106# sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, s - SSM Group, C - Connected, L - Local,
P - Pruned, R - RP-bit set, F - Register flag, T - SPT-bit set,
J - Join SPT, M - MSDP created entry, X - Proxy Join Timer Running
A - Advertised via MSDP, U - URD, I - Received Source Specific Host
Report
Outgoing interface flags: H - Hardware switched
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.9.1), RP 169.123.90.102, flags: SJPC
Incoming interface: Tunnel0, RPF nbr 169.128.38.2, Partial-SC
Outgoing interface list: Null
(165.21.4.50, 239.255.9.1), 2d06h/00:03:19, flags: T
Incoming interface: GigabitEthernet1/2, RPF nbr 165.25.4.2, Partial-SC
Tunnel0, Forward/Sparse-Dense, 2d06h/00:03:03
(165.21.4.52, 239.255.9.1), 2d06h/00:03:29, flags: T
(165.21.4.53, 239.255.9.1), 2d06h/00:02:58, flags: T
Tunnel0, Forward/Sparse-Dense, 2d06h/00:03:02
(165.21.4.54, 239.255.9.1), 6d14h/00:03:28, flags: T
Tunnel0, Forward/Sparse-Dense, 6d13h/00:03:02
(165.21.4.55, 239.255.9.1), 2d06h/00:03:18, flags: T
1 REPLY
Bronze
Re: Multicast Output explanation
6d14h/ means 6 days, 14 hours and "stopped" means that timing out of this entry is not determined by this expire timer.
429
