Multicast PIM Sparce mode
Hi guys,
I have configured ip multicast-routing on my cisco routers to forward video stream traffic through multicast.
On article I'm reading from they only have configuration for the routers but I also need the configuration for the layer 3 switch 4500 series.
Can anyone guide me. thanks in advance.
I have the following configuration:
routers participating on multicast: globla config-----------#ip multicast-routing
on all routers announcing the roundezvous point:--------#ip pim rp-address 192.168.181.1
on interface participating on multicast traffic:--------------#ip pim sparce-mode
on router with multicast clients-------------------------------# ip igmp join-group 236.x.x.x
I did for CME MOH on
I did for CME MOH on 4507
interface Vlan16//
 description ///Vlan
 ip address 192.////
 ip helper-address 192.///
 ip pim sparse-mode
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of   the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Your L3 switch config should be similar to your router config.  (It helps with questions like these if you also identify your supervisor and the IOS version you're running.)
Unclear why you're using the igmp join-group command.
Also BTW, I believe, the ip pim rp-address doesn't announce, it tells that router what's the RP IP is;  although RP IP can be announced.  (Your RP is well selected?)
72
