Multicast problems on catalyst 2950 v12.1(9)EA1
Hello.
I have the following scenario:
2 Firewall1in load-balance - FW1 and FW2
2 catalyst 2950 48 ports with 12.1(9) EA1 version - SW1 and SW2
FW1 is plugged to SW1 by trunk on interface G0/1, FW2 is plugged to SW2 by trunk on interface G0/1 and between switches there is a trunk fyber link on interface G0/2 on each switch.
The ip igmp snooping feature is disabled and multicast mac-addresses are statically defined on interfaces G0/1 and G0/2 on each switch.
It seems to me that if i have a PC connected to SW1, packets arrive to FW1 with right tagging on correct VLAN and to FW2 without tag.
Hence, FW2 will discard the packets and connectivity will be lost.
With 2 FW and just one switch everything works well. This scennario drives me to point to a multicast problem or a bug not reported on these
release.
Do you advice any workaround?
Maybe an upgrade to new version 12.1(12c)EA1...
Silver
Re: Multicast problems on catalyst 2950 v12.1(9)EA1
An upgrade would be a good idea if you feel the problem is possibly due to a bug.
However the following doc on Multicast Troubleshooting might help you rule out any possible problems.
http://www.cisco.com/en/US/tech/tk648/tk363/technologies_tech_note09186a0080094b55.shtml
You expect the multicast will be send bi-directional over a single link. This will introduce a classic bridge loop and is not permitted, even this is recommended by some FW suppliers!
Regard’s Andy
I have the same scenario working with catalyst 3550 L3 with just layer 2 !!
Beside this all gigabit ports of the catalyst 2950 are in forwarding state so, i think this is not a loop problem and i didn't detect any blocked state. The Firewalls should prevent eventual loops!!!!
Thanks Nuno
172
