Multicast Routing across VLANs with C3560G-24TS-E(L3) and 2950T(L2)
cratejockey
First off what limited experience I have have with imaging and multicasting has had to do with single VLAN or WAN implementations of Multicast services.
My configuration is as follows:
3560G (Acting as the gateway for VLANs 10, 100-1006, 200-206 and 300) with IP and Multicast routing enabled
5 x 2950T each with a 1Gig link back to the 3560 in 802.1q trunking mode with all VLANs allowed across the trunk
My VLANs each exist on multiple switches.
My 3560 config is as follows:
no aaa new-model
clock timezone eastern -5
ip subnet-zero
ip routing
ip multicast-routing distributed
password encryption aes
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback0
no ip address
___________
Physical Interfaces removed
___________
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.83.176.129 255.255.255.128
ip helper-address 10.83.176.150
ip pim dense-mode
interface Vlan30
no ip address
interface Vlan100
ip address 10.83.177.1 255.255.255.0
ip pim dense-mode
interface Vlan101
ip address 10.83.178.1 255.255.255.0
ip pim dense-mode
interface Vlan102
ip address 10.83.179.1 255.255.255.0
ip pim dense-mode
interface Vlan103
ip address 10.83.180.1 255.255.255.0
ip pim dense-mode
interface Vlan104
ip address 10.83.181.1 255.255.255.0
ip pim dense-mode
interface Vlan105
ip address 10.83.182.1 255.255.255.0
ip pim dense-mode
interface Vlan106
ip address 10.83.183.1 255.255.255.0
ip pim dense-mode
interface Vlan200
ip address 10.83.184.1 255.255.255.0
no ip redirects
ip pim dense-mode
interface Vlan201
ip address 10.83.185.1 255.255.255.0
ip pim dense-mode
interface Vlan202
ip address 10.83.186.1 255.255.255.0
ip pim dense-mode
interface Vlan203
ip address 10.83.187.1 255.255.255.0
ip pim dense-mode
interface Vlan204
ip address 10.83.188.1 255.255.255.0
ip pim dense-mode
interface Vlan205
ip address 10.83.189.1 255.255.255.0
ip pim dense-mode
interface Vlan206
ip address 10.83.190.1 255.255.255.0
ip pim dense-mode
interface Vlan300
ip address 10.83.191.1 255.255.255.0
ip pim dense-mode
router eigrp 100
redistribute connected
redistribute static
network 10.83.176.0 0.0.15.255
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/24
ip http server
Example of one of the 2950 Configs:
ip subnet-zero
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 10
speed 100
duplex full
spanning-tree portfast
interface GigabitEthernet0/1
switchport mode trunk
switchport nonegotiate
speed 1000
duplex full
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 10.83.176.130 255.255.255.128
no ip route-cache
interface Vlan100
no ip address
no ip route-cache
shutdown
ip http server
At this point I am unable to see multicast offered by a multicast image server and I am also unable to see bonjour offered printers across VLANS. I am clearly missing something and I hope that someone will have a quick answer for this issue.
Josh
12 Replies 12
Roberto Salazar
Level 8
Level 8
Can you tell us where the image server is coming from? First the router have to build the source tree, then the shared tree, then the SPT. so, knowing the topology and the location of where the source is coming from is important. Knowing that, you will be able to look at the following:
1. show ip mroute >> this will tell you whether there is a (*,G) entry and if the interface going to the receiver on the (S,G) are forwading or not. This will eliminate if we need to be troubleshooting at Layer 3 or we need to look at Layer 2 igmp. So, can you gather these information?
1. Topology, show where the server srving the image and the receiver are connected.
2. show ip mroute
3. show ip igmp group this will show if there are reports coming from that subnet having problem.
Please rate helpful posts.
No problem:
The Server (source) is connected to the 3560 on Interface Gig0/1 in VLAN 10 (10.83.176.128 as address 10.83.176.150)
1.
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.253), 00:59:32/stopped, RP 0.0.0.0, flags: DC
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Vlan10, Forward/Dense, 00:59:32/00:00:00
(10.83.176.137, 239.255.255.253), 00:02:57/00:00:55, flags: PT
Incoming interface: Vlan10, RPF nbr 0.0.0.0
Outgoing interface list: Null
(*, 239.255.255.250), 00:59:16/00:02:04, RP 0.0.0.0, flags: DC
Vlan100, Forward/Dense, 00:59:16/00:00:00
(*, 224.77.2.121), 00:52:52/stopped, RP 0.0.0.0, flags: DP
(10.83.176.150, 224.77.2.121), 00:52:52/00:02:54, flags: PT
(*, 224.0.1.60), 00:59:11/00:02:06, RP 0.0.0.0, flags: DC
Vlan100, Forward/Dense, 00:59:11/00:00:00
(*, 224.0.1.40), 00:59:35/00:02:04, RP 0.0.0.0, flags: DCL
Vlan10, Forward/Dense, 00:59:35/00:00:00
2.
sh ip mroute 224.77.2.121
(*, 224.77.2.121), 01:03:18/stopped, RP 0.0.0.0, flags: DC
Vlan10, Forward/Dense, 00:06:17/00:00:00
(10.83.176.150, 224.77.2.121), 01:03:18/00:02:59, flags: PT
3.
GE_3560_1#sh ip igmp group 224.77.2.121
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
224.77.2.121 Vlan10 00:06:55 00:02:08 10.83.176.140
Ok I have ammended my initial post. I think that I figured out the group address. If 224.77.2.121 isnt what you were looking for let me know.
Josh
Anyone have more feedback concerning this?
hmm, you did not not say which vlan is not recieving the mcast stream but from the output you've provided:
3.
mroute shows that it's not forwarding on vlan 10 but that's normal it's where the source is coming from, there is no need for L3 mcast. and the igmp roup tells me there is only one host requesting for the stream which is host with ip address 10.83.176.140. The output looks normal, what is the issue?
The issue is that only VLAN 10 clients can see multicast traffic. I need my entire network to be able to see multicast traffic for Bonjour and Netimaging via Multicast. I have enabled ip igmp snooping from global config on the 3650 and I am getting more mroute info as follows.
(*, 239.255.255.253), 04:32:09/00:02:59, RP 0.0.0.0, flags: DC
Vlan10, Forward/Dense, 00:04:09/00:00:00
(*, 239.255.255.250), 04:31:53/00:01:58, RP 0.0.0.0, flags: DC
Vlan100, Forward/Dense, 04:31:53/00:00:00
(*, 224.0.1.60), 04:31:47/00:02:54, RP 0.0.0.0, flags: DC
Vlan10, Forward/Dense, 00:23:26/00:00:00
Vlan201, Forward/Dense, 00:29:15/00:00:00
Vlan100, Forward/Dense, 04:31:47/00:00:00
(*, 224.0.1.40), 04:32:10/00:02:55, RP 0.0.0.0, flags: DCL
Vlan10, Forward/Dense, 04:32:10/00:00:00
However as stated above I am still not able to see multicast traffic generated on any subnet on any other subnet but its own.
Thanks for the help so far I hope you stick with me on, this multicast issue is really killing this project.
thanks.
Like I said, there is only one requester for that mcast traffic. No report to stream.
Multicast will not just inadvertantly send mcast traffic to any segment. there must be a report or a join coming from the host. For the particular group you've captured there is one one host that sent a join and that is from the host with ip address 10.83.176.140.
I will assist you torubleshooting but you need to give me details.
1. Let's start with one vlan, which vlan is not able to get the stream from 224.77.2.121. 2. Select a host to test from that vlan and tell me what switch it is connected to and how it (the switch that the host connects to) connects to the 3560.
3. From the switch where the host used for testing do the following:
show ip igmp snooping vlan #
show ip igmp group
show ip igmp mrouter
Let start from there, I hope I am clear with the procedure.
1. The stream is initiated on VLAN 10 (10.83.176.128 255.255.255.128). The listener is in VLAN 100 (10.83.177.0 255.255.255.0). The switch connects via Cat5 from Gig 0/1 onf the 2950 to Gig 0/23 on the 3560. Both ends of the connection are configured to 100 Full, set as trunks using 802.1x trunking with all vlans allowed accross the trunk. The client is on FE 0/11 of the 2950.
3.
show ip igmp snooping vlan 10 Results:
GE_3560_1#show ip igmp snooping vlan 10
Global IGMP Snooping configuration:
IGMP snooping : Enabled
IGMPv3 snooping (minimal) : Enabled
Report suppression : Enabled
TCN solicit query : Disabled
TCN flood query count : 2
Last Member Query Interval : 1000
Vlan 10:
IGMPv2 immediate leave : Disabled
Explicit host tracking : Enabled
Multicast router learning mode : pim-dvmrp
CGMP interoperability mode : IGMP_ONLY
show ip igmp snooping vlan 100 Results:
GE_3560_1#show ip igmp snooping vlan 100
Vlan 100:
show ip igmp group 224.77.2.121 Results:
Group 224.77.2.121 not found
show ip igmp mrouter Results: did not exist, however ip igmp snooping mrouter does and returned:
GE_3560_1#sh ip igmp snooping mrouter
Vlan ports
10 Router
100 Router
101 Router
102 Router
103 Router
104 Router
105 Router
106 Router
200 Router
201 Router
202 Router
203 Router
204 Router
205 Router
206 Router
300 Router
For what its worth 224.77.2.121 is the Multicast group that we are broadcasting our image on at this moment. I do not see this group anywhere in my multicast routes.
Thanks for your ongoing help.
maybe I was not clear but I ask for the following:
show ip igmp group
you gave me the right output but from the wrong switch, you should capture this output from the 2950 becuase you said "The client is on FE 0/11 of the 2950."
1. The listener is in VLAN 100 (10.83.177.0 255.255.255.0). The switch connects via Cat5 from Gig 0/1 on the 2950 to Gig 0/23 on the 3560.
2.
show ip igmp snooping vlan 100 Results from 2950:
GE_2950_1#show ip igmp snooping vlan 100
Last member query interval : 1000
Vlan 100:
Immediate leave : Disabled
Source only learning age timer : 10
show ip igmp group : Does not exist however sh ip igmp group does:
GE_2950_1#sh ip igmp snooping group
Vlan Group Version Port List
10 224.0.1.40 v2 Gi0/1
102 224.0.1.60 v1 Fa0/38, Fa0/40, Fa0/43, Fa0/47
show ip igmp mrouter Results on 2950: Does not exist however sh ip igmp snooping mrouter returns
GE_2950_1#sh ip igmp snooping mrouter
Vlan ports
10 Gi0/1(dynamic)
100 Gi0/1(dynamic)
101 Gi0/1(dynamic)
102 Gi0/1(dynamic)
103 Gi0/1(dynamic)
104 Gi0/1(dynamic)
105 Gi0/1(dynamic)
106 Gi0/1(dynamic)
200 Gi0/1(dynamic)
201 Gi0/1(dynamic)
202 Gi0/1(dynamic)
203 Gi0/1(dynamic)
204 Gi0/1(dynamic)
205 Gi0/1(dynamic)
206 Gi0/1(dynamic)
300 Gi0/1(dynamic)
2950 knows where the mrouter ports shoould be and so it knows where to forward the igmp join that the listener generates when it wants to subscribe to that group address. Now, you have to make sure that the group address is correct and if even the listener is sending a join. without a join the sender will never send, otherwise, it might as well just use broadcast. you have a couple of ways of troubleshooting this. 1. Take a sniffer capture of port 0/11 on 2950 where you said the listener in vlan 100 is connected. Try to subscribe to the group from the listener, as soon as you do this the client should generate a join. If we see a join then we need to know whether the 2950 is forwarding that join to 3560 which is the mcast router. That will mean another sniffer trace on gig 0/23 of the 3560.
2. Or try to disable the igmp snooping on 2950 and see the client is not able to get the stream. What disabling the igmp snooping does is the 2950 will just flood the mcast stream to all the ports, if there is a stream to flood.
and there is a another way to see if we can force the router to send stream but you need to make sure that the group address is actually the group address you've indicated. You can try putting in "ip igmp join-group 224.77.2.121" under the interface vlan 100 of the 3560.
Thanks for your ongoing support on this issue. Things are starting to be a bit less murky. However I need to clarify what you are saying about joins.
How does the listener know what group it is trying to join? How to I get the listener to try to subcribe? All of this is happening in the clients ARD console. On VLAN 10 a client automatically sees the multicast offering. On VLAN 100 it never does.
I'm going to try to disable snooping as you stated but I think overall my issue lies with my groups. Is the group something that I can set to anything in the standard Multicast range?
If we are moving backware feel free to let me know and I'll walk away from this for tonight and read more about multicast.
Per IGMP's general operation there is a join that needs to come from the client. However, the client is configured it must generate a join to a particualr group it need to get the stream from. The best thing to do probably is to sniff the port and see if you get any kind of join. You have a segment where the mcast is working, if you sniff that you would see an IGMP join at the beginning of the communication from the client. There are three IGMP version but the general operation is the same. Maybe you should look at the IGMP RFC:
IGMP v1 - RFC 1112
IGMP v2 - RFC 2236
IGNP v3 - RFC 3336
INTRODUCTION TO MULTICAST:
http://www.cisco.com/application/pdf/en/us/guest/products/ps6552/c1161/cdccont_0900aecd80310883.pdf
