Webcast-Catalyst9k
MULTICAST ROUTING
Ihad a problem wich exactly fit CSCdt39794.
Is there anyone which can clarify the bypass .
It is not very clear how it may works...
thanks.pascale
1 REPLY
Silver
Re: MULTICAST ROUTING
The workaround is to configure a static route from the source of the multicast to the interface that has high utilization. Ex: ip route 10.1.1.1 255.255.255 ethernet 1. 10.1.1.1 is the source of the multicast and ethernet 1 is the interface with the high CPU.
106
