Multicast routing
How do I enable multicast routing between a Cisco 6509 and a Marconi ESR5000?
I am replacing our ESR5000 with the Cisco 6509.
This is a gradual move our 600 users on 10 different VLANs.
I need to enable the multicast routing to allow my Netware IP Servers and users to communicate with the SLPDA Netware Server that is on a different VLAN.
Per Novell Document 2944038, which is also a document on Cisco Tech Support network site, I enabled the "ip multicast-routing" command globally and enabled the "ip pim dense-mode" command under each VLAN.
I am able to multicast access the SLPDA server on the ESR5000 from each VLAN on the 6509 as long as
that VLAN has a IP IGMP interface enabled on the ESR5000. I found information that indicated that I needed to enable DVMRP on the interface between 2 routers to allow multicast access between them. I did this on the one VLAN I use as my connection between the ESR5000 and 6509 and it disabled the multicast connection I had with that VLAN plus all others that were previously working with IP interface on both routers.
Thanks, Ken
1 REPLY
Silver
Re: Multicast routing
This document has some of the details you are looking for :
http://www.cisco.com/en/US/tech/tk828/tk363/technologies_tech_note09186a0080093f21.shtml
310
