Multicast Routing
Please can you help.
I have enabled multicast on our network which seem to be working fine only to find out that workstations in the same vlan as the servers sending out traffic do not receive multicast.
What I have configured is the ff on the router:
ip pim send-rp-announce Vlan615 scope 16
ip pim send-rp-discovery scope 16
Then
no ip redirects
ip pim sparse-dense-mode
ip igmp version 1
ip cgmp
on each participating vlan
All other workstations in vlans such as 610, 611 and others receive multicast but not those in vlan 610 although these workstations receive multicast from servers in vlan 610.
Please why is this?
1 REPLY
Re: Multicast Routing
Please make sure you have cgmp/igmp snooping configured on the switches. Also, any particular reason why you have igmp v1 configured? In general most modern host stacks run v2, and the router running v2 can run in v1 interoperability mode if v1 hosts are detected.
You may want to check your L2 forwarding table for multicast on the switches to make sure the group MAC is installed & the correct ports are in the port list.
Last resort, I would suggest opening a TAC case as this may be difficult to get to the bottom of through this mechansim.
84
