I have a 6513 switch IOS and i want to do streaming for different vlans. I have enabled pim in the interfaces and igmp on the switches, but only can view streaming on the same vlan, in which is the source of streaming.
Without seeing the outputs requested it's difficult to see.
However, it seems as thought the PIM is not working correctly, did you put in the command "ip multicast routing" to enable it on the box?
LH
Please rate all posts
