Silver
Multicasting problems
Hello All
I got some problems with setting up multicast in a routed, firewalled enviroment.
Please see my thread http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddc32ef
for more info.
I hope that here somebody can help.
patrick
Re: Multicasting problems
Hi there,
What is the multicast config on your 6500 between vlan 200 and vlan 15 ?
LH
Silver
on vlan 200 it's:
igmp forward interface transit1 (which is the 6500 router)
On vlan 15 is nothing special configured.
I don't know the FWSM too well, so I won't comment on your configs. One thing I would like to point out though is that most of the times, multicast issues with Ghost are due to the TTL not being set to a value greater than one, which allows the packets to traverse a L3 device.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Silver
Hmm...
This TTL could be it then indeed, currently it's set on default and I think that means it's 0.
Will change that and inform you.
Actually, where could I find this TTL setting in the CSM?
Or is that on the router side?
The TTL would need to be changed on the Ghost server.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Silver
I tested it now, it didn't work.
I got you some FWSM log, maybe you can right spot it. I'm not yet a proffessional, so I probably don't recognize it.
19-09-2006 08:21:10 %FWSM-6-302016: Teardown UDP connection 221473793 for transit1:152.96.25.81/68 to server2:a.a.21.10/67 duration 0:03:39 bytes 1038
19-09-2006 08:21:11 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to server1:229.55.150.208/1345 duration 0:02:03 bytes 2
19-09-2006 08:21:11 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to server2:229.55.150.208/1345 duration 0:02:03 bytes 2
19-09-2006 08:21:11 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to verw-client:229.55.150.208/1345 duration 0:02:03 bytes 2
19-09-2006 08:21:11 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to dozpers:229.55.150.208/1345 duration 0:02:03 bytes 2
19-09-2006 08:21:12 %FWSM-6-302016: Teardown UDP connection 219025313 for transit1:a.a.25.81/1346 to dozpers:a.a.201.66/1347 duration 0:21:11 bytes 36097
19-09-2006 08:21:12 %FWSM-6-302016: Teardown UDP connection 219025317 for dozpers:a.a.201.66/1345 to transit1:a.a.25.81/1346 duration 0:03:40 bytes 1743
19-09-2006 08:22:20 %FWSM-6-302016: Teardown UDP connection 219025319 for dozpers:a.a.201.66/6666 to transit1:a.a.25.81/1025 duration 0:03:36 bytes 918
19-09-2006 08:22:20 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1025 to dozpers:224.77.0.0/6666 duration 0:02:03 bytes 0
19-09-2006 08:23:24 %FWSM-6-302014: Teardown TCP connection 219025327 for transit1:a.a.25.81/1025 to dozpers:a.a.201.66/1347 duration 0:00:00 bytes 10611 TCP FINs
19-09-2006 08:25:23 %FWSM-6-302016: Teardown UDP connection 219025324 for transit1:a.a.25.81/7777 to dozpers:a.a.201.66/1270 duration 0:05:05 bytes 2920
19-09-2006 08:25:26 %FWSM-6-302016: Teardown UDP connection 219025325 for dozpers:a.a.201.66/1345 to transit1:a.a.25.81/1346 duration 0:02:03 bytes 1162
19-09-2006 08:25:27 %FWSM-6-302016: Teardown UDP connection 221474355 for transit1:a.a.25.81/68 to server2:a.a.21.10/67 duration 0:02:03 bytes 692
19-09-2006 08:25:48 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to server1:229.55.150.208/1345 duration 0:02:03 bytes 1
19-09-2006 08:25:48 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to server2:229.55.150.208/1345 duration 0:02:03 bytes 1
19-09-2006 08:25:48 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to verw-client:229.55.150.208/1345 duration 0:02:03 bytes 1
19-09-2006 08:25:48 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to dozpers:229.55.150.208/1345 duration 0:02:03 bytes 1
19-09-2006 08:31:49 %FWSM-6-302014: Teardown TCP connection 219025328 for transit1:a.a.25.81/1025 to dozpers:a.a.201.66/1347 duration 0:00:00 bytes 2195 TCP FINs
19-09-2006 08:32:32 %FWSM-6-302014: Teardown TCP connection 219025329 for transit1:a.a.25.81/1025 to dozpers:a.a.201.66/1347 duration 0:00:20 bytes 64 SYN Timeout
19-09-2006 08:32:33 %FWSM-6-302014: Teardown TCP connection 219025330 for transit1:a.a.25.81/1025 to dozpers:a.a.201.66/1347 duration 0:00:00 bytes 718 TCP FINs
19-09-2006 08:33:42 %FWSM-6-302014: Teardown TCP connection 219025332 for transit1:a.a.25.81/1025 to dozpers:a.a.201.66/1374 duration 0:00:00 bytes 5678 TCP FINs
19-09-2006 08:34:37 %FWSM-6-302016: Teardown UDP connection 219025326 for transit1:a.a.25.81/1346 to dozpers:a.a.201.66/1347 duration 0:11:12 bytes 15778
19-09-2006 08:35:45 %FWSM-6-302016: Teardown UDP connection 219025331 for dozpers:a.a.201.66/6666 to transit1:a.a.25.81/1025 duration 0:02:03 bytes 612
19-09-2006 08:35:45 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1025 to dozpers:224.77.0.0/6666 duration 0:02:03 bytes 0
Silver
19-09-2006 08:36:37 %FWSM-6-302014: Teardown TCP connection 219025336 for transit1:a.a.25.81/1025 to dozpers:a.a.201.66/1347 duration 0:00:00 bytes 10714 TCP FINs
19-09-2006 08:38:36 %FWSM-6-302016: Teardown UDP connection 219025333 for transit1:a.a.25.81/7777 to dozpers:a.a.201.66/1373 duration 0:04:53 bytes 2920
19-09-2006 08:38:38 %FWSM-6-302016: Teardown UDP connection 219025334 for dozpers:a.a.201.66/1345 to transit1:a.a.25.81/1346 duration 0:02:03 bytes 1162
19-09-2006 08:38:41 %FWSM-6-302016: Teardown UDP connection 221475149 for transit1:a.a.25.81/68 to server2:a.a.21.10/67 duration 0:02:03 bytes 692
19-09-2006 08:39:01 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to server1:229.55.150.208/1345 duration 0:02:03 bytes 1
19-09-2006 08:39:01 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to server2:229.55.150.208/1345 duration 0:02:03 bytes 1
19-09-2006 08:39:01 %FWSM-6-302016: Teardown UDP connection 0 for transit1:a.a.25.81/1346 to verw-client:229.55.150.208/1345 duration 0:02:03 bytes 1
19-09-2006 08:39:01 %FWSM-6-302016: Teardown UDP connection 0 for transit1:152.96.25.81/1346 to dozpers:229.55.150.208/1345 duration 0:02:03 bytes 1
This are a few trials of my colleague who administrates the ghost server.
Patrick
318
