08-12-2002 03:12 PM - edited 03-02-2019 12:38 AM
How do I place a priority on a bri interface so that the same channel is the first and only permanent connection and the others DOD.
08-13-2002 10:53 AM
You can't prioritize a particular B channel within a BRI; the switch tells the cisco which B-channel to use each time a call is placed. You can prioritize multiple BRI interfaces that are all in a rotary-group; you would do that with the "dialer priority" command under the BRI interfaces.
08-16-2002 11:57 AM
Do you mean you wish to bring up the second channel only if required? If so, you can use the dialer load-threshold command. For example:
dialer-load threshold 128
will only bring up a second channel if the first one is at 50% capacity.
08-18-2002 01:50 PM
Overview, Customer is paying for a permanent connection on only one channel which will be up all the time, he also has the capacity for three more channels to come up on demand. I have configured this OK. But I need to ensure that the one permanent channel is always on the same BRI.
