Webcast-Catalyst9k
Multilink bundling issue
hi
i hve pasted the o/p of my sh ver taken out from my cisco 3660 routers i m planning to run 3*2Mbps in multilink between 2 locations which r having the same config.my query is will the routers able to handle these mulitlinks.in addition to this we r running bgp (both EBGP/IBGP) and OSPF with other peers already in these routers.
right now the cpu util is coming under 13% on average basis.
IOS (tm) 3600 Software (C3660-IK8S-M), Version 12.2(3), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 18-Jul-01 22:27 by pwade
Image text-base: 0x600089C0, data-base: 0x61340000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
System restarted at 04:47:34 IST Tue Oct 21 2003
System image file is "flash:c3660-ik8s-mz.122-3.bin"
cisco 3660 (R527x) processor (revision 1.0) with 122880K/8192K bytes of memory.
Processor board ID JAB0540803S
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
3660 Chassis type: ENTERPRISE
2 FastEthernet/IEEE 802.3 interface(s)
30 Serial network interface(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
prem
Re: Multilink bundling issue
Running PPP multilink on 3 extra E1's is not that much of a load for the 3660. It's ok.
Cheers
Three E1s bundled with MLPPP might add a fair amount of CPU overhead, IMHP (In My Humble Prediction). Tough to predict, of course. Depends not only on all other configured features but, especially, the traffic load. If you find CPU utilization high on one end or the other, I highly recommend turning off MLPPP frame fragmentation. In the MLPPP interface configuration, the command is "no ppp multilink fragmentation" or "ppp multilink fragment disable," depending on the IOS version. I'm not certain which one with your version, but the former one is the older command.
202
