Multilink Frame-relay on Frame-ATM internetworking circuit
Is it possible to configure multilink Frame-relay on a Frame-ATM internetworking circuit.
We have a E1 Frame circuit with 2 Meg Frame-ATM internetworking, and now there is a requirement to have 4 Meg PVC. However, since ATM is not available at the remote site and we need to check if configuring Multilink Frame-relay will solve the problem.
1 REPLY
Re: Multilink Frame-relay on Frame-ATM internetworking circuit
I believe you can do and make sure your service provider will be able to support the MFR. So they will terminate the MFR and translate to ATM.
Here is the useful link.
http://www.cisco.com/en/US/tech/tk652/tk692/technologies_tech_note09186a00800b6098.shtml
Cheers
/Bessie
95
