Webcast-Catalyst9k
Multilink PPP Problem
I configured a Multilink Interface with two Serial Interfaces Ser1a-Ser1b and Ser2a-Ser2b. This Configuration works between 1 and 2 Days then no IP Packet goes over the Multilink Interface, in this State all Interfaces Multilink1a, Multilink1b, Ser1a, Ser1b, Ser2a an Ser2b are up. I reset one of the Serial Interfaces, then the Multilink is ok.
The Configuration is:
interface Multilink1
ip address xxx.yyy.zzz.xxx xxx.xxx.xxx.xxx
no cdp enable
ppp multilink
multilink-group 1
interface Serial2/0
bandwidth 1920
no ip address
encapsulation ppp
no ip mroute-cache
no keepalive
no peer default ip address
no fair-queue
no cdp enable
ppp multilink
multilink-group 1
hold-queue 4096 in
hold-queue 4096 out
interface Serial2/1
bandwidth 1920
no ip address
encapsulation ppp
no ip mroute-cache
no keepalive
no fair-queue
no cdp enable
ppp quality 80
ppp multilink
multilink-group 1
hold-queue 4096 in
hold-queue 4096 out
What am i doing wrong?
Any Help is welcome
Thomas
Silver
Re: Multilink PPP Problem
on S2/1 you are using ppp quality 80 this could be the reason it stops functioning , when you reset the interface the reliability is reset .
Are there any erros on s2/1 or what it is attached to ?
thank you for your fast response. I made a mistake with copy and paste "ppp quality is configured on all serial interfaces and in the moment we are using the multilink with only one serial connection without any problems. Only with two serials the problem occurs.
I have no errors on the serial interfaces.
Attached on the serial interfaces are Controlware Primus G.703 -> X21 Converter.
Thomas
Silver
what do the serial interfaces on the remote side look like ?
the configuration of the Interfaces is identical.
Thomas
Silver
can you paste in a sh interface serial x from both ends
Silver
for the Moment only one serial connection is in the Multilink.
Router a ser 2/1 is connected with Router b ser 2/0
Router a
#sh int ser 2/1
Serial2/1 is up, line protocol is up
Hardware is M4T
Description: xxxxxxxxxxxxxxxxxxxxxxxx
MTU 1500 bytes, BW 1920 Kbit, DLY 20000 usec,
reliability 255/255, txload 17/255, rxload 76/255
Encapsulation PPP, crc 16, loopback not set
Keepalive not set
LCP Open, multilink Open
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w0d
Queueing strategy: fifo
Output queue 0/4096, 0 drops; input queue 24/4096, 0 drops
5 minute input rate 573000 bits/sec, 79 packets/sec
5 minute output rate 133000 bits/sec, 62 packets/sec
29950357 packets input, 335251973 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
136 input errors, 112 CRC, 0 frame, 0 overrun, 0 ignored, 24 abort
26648262 packets output, 354103059 bytes, 0 underruns
0 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Router b
#sh int ser 2/0
Serial2/0 is up, line protocol is up
Hardware is M4T
Description:xxxxxxxxxxxxxxxxxxxxxxxxxxx
reliability 255/255, txload 108/255, rxload 38/255
Keepalive not set
Last clearing of "show interface" counters 3w0d
Output queue 0/4096, 0 drops; input queue 462/4096, 0 drops
5 minute input rate 292000 bits/sec, 101 packets/sec
5 minute output rate 816000 bits/sec, 124 packets/sec
70469717 packets input, 615352921 bytes, 144 no buffer
55 input errors, 38 CRC, 0 frame, 0 overrun, 0 ignored, 17 abort
78739185 packets output, 2191565971 bytes, 0 underruns
0 output errors, 0 collisions, 38 interface resets
38 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
Thomas
Silver
you are taking errors and carrier transitions across this link , I would clear the counters and watch it , when it happens again look to see if you received a burst of errors or carrier transtions that could have caused this , If you have an internal CSU you can do a sh service-module serialx performance stats , this will give you the last 96 15 minute intervals and how many errors occured during these times .
it's a IOS bug ,try to upgrade the ios or try
to put fair-queue on all interface
we are using IOS Version 12.2(1)on Cisco 3640. Do you know the release in which the bug was fixed.
Thomas
thank you for your response.
Can you tell me why enabling fair-queue can solve the problem.
Thomas
499
