Multilink with Serial- and BRI-IF on 2503
Hello all,
I have two routers with IOS 12.0(27) on it. There's a leased line which works with the ser0-interface only and there's a ISDN-line with two b-channels which works (mostly) with the bri0-if only.
Now I want to do/to have the following to get work:
the leased-line with the ser0-interfaces on both sides should be for the basic traffic. After reaching a threshold, the first b-channel should come up.
I tried to do this via a dialer rotary-group and put the ser0 and bri0-if in it.
I worked, until the dialer-idle time was reached and then the VirtualAcces-IF goes down and never comes up again. After resetting the external X.21-Modem for the ser0-IF on one side the VirtualAccess-IF comes up again and so on.
In this case the bri0 did not come up to handle the traffic instead of the ser0-IF.
Switching on the debugging I could see, that the ser0-IF got the dialer-string with the phone-number for the bri0-if, maybe that's the reason for crashing the external modem.
I got help in the web in that way, that I should configure the ser0 with dialer dtr, dialer pool-member 1, dialer priority 10 and the bri0 with dialer pool-member 1 and dialer priority 5. It worked for the ser0, but not for the bri0-IF.
Now, is it possible to combine the leased-line for basic traffic with a ISDN-line in that way using the dialer threshold and dialer rotary-group?
What is an other possibility for expanding the bandwith using my hardware?
I post the config of the both routers - maybe it helps, and maybe anyone knows a way to do this...
Router A:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname router-b
no logging buffered
no logging console
no logging monitor
enable secret xxxxx
username router-a password xxxxx
ip subnet-zero
isdn switch-type basic-net3
interface Ethernet0
ip address 192.168.5.9 255.255.255.0
ip helper-address 192.168.94.5
ip helper-address 192.168.94.23
no ip directed-broadcast
interface Serial0
no ip address
encapsulation ppp
no ip mroute-cache
shutdown
dialer in-band
no fair-queue
pulse-time 1
ppp authentication chap
ppp multilink
interface Serial1
no ip address
shutdown
interface BRI0
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
no keepalive
dialer rotary-group 1
no fair-queue
interface Dialer1
ip address x.x.x.1 255.255.255.0
encapsulation ppp
dialer in-band
dialer map ip x.x.x.2 name router-a broadcast 010519474439
dialer load-threshold 40 either
dialer-group 1
no fair-queue
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.5.1
ip route 192.168.1.0 255.255.255.0 200.200.205.2
logging source-interface Ethernet0
logging x.x.94.31
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
snmp-server community zit4mrtg RO
line con 0
transport input none
line aux 0
transport input all
line vty 0 4
password xxxxx
login
end
Router B:
version 12.0
hostname router-a
no logging buffered
no logging console
no logging monitor
enable secret xxxx
enable password xxxxx
username router-b password xxxxxx
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address x.x.x.33 255.255.255.252
interface Ethernet0
interface Serial0
no ip address
encapsulation ppp
no ip mroute-cache
shutdown
dialer in-band
no fair-queue
pulse-time 1
ppp multilink
interface Serial1
no ip address
shutdown
interface BRI0
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
interface Dialer1
ip address x.x.x.2 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 300
dialer map ip x.x.x.1 name router-b broadcast 0105134583
dialer-group 1
no fair-queue
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 200.200.205.1
no logging trap
access-list 100 deny udp any any eq netbios-ns
access-list 100 permit ip any any
access-list 100 deny udp any any eq netbios-dgm
line con 0
line aux 0
transport input all
line vty 0 4
password xxxx
login
end
1 REPLY
Bronze
Re: Multilink with Serial- and BRI-IF on 2503
See if you can use the 'backup interface' and 'backup load' commands on the serial interface. This link has more information :
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/dialts_c/dtsprt6/dcdbaks.htm
256
