Multiple BRI interfaces using Dial on Demand
We currently use Dial on Demand for some remote links. One particular site is configured to run at 64K but using load-threshold it goes up to 128K during peaks times.
This site looks like increasing in size. Is it possible to configure more than one BRI interface for the DIal on Demand & load-threshold. So that it can go from 64-256K as the traffic increases. E.g Dials up more lines as required.
Alistair
Re: Multiple BRI interfaces using Dial on Demand
Yes it is possible. My recommendation is to change (if you haven't already) your Dial on Demand to use Dialer interfaces. That is at the "initiating" end, configure your physical BRI interfaces as "dialer pool-member x" and configure your Dialer interface as "dialer-group x". There are examples of this type of configuration on Cisco web site. Have a look at this as an example: http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080093c2e.shtml#diag
I'm currently using "dialer pool" in the BRI & "dialer group" in the Dialer interface. Do I need to configure the next BRI as the same dialer pool?
130
