Multiple L2TP Tunnels ending on the same Cisco device (3620, 2620)
I need to find a possibility to terminate multiple l2tp tunnels on different virtual interfaces so that each tunnel can have a different address range (dhcp or pool).
This is needed to allow external company to have access to our network but with a dedicated ip address which is different from the one of the internal l2tp users.
thanks for your help
tepatel
You can do that..You need to create the multiple vpdn groups on the HGW..Now you can terminate the users on a different virtual interface based on that vpdn groups..Just need to mantion the different pool of ip address to be allocated to different vpdn tunnel users. Here is the url which discuss that
http://www.cisco.com/warp/public/793/access_dial/2.html
Hope this helps..Thx..Tejal
