Community Member
multiple RR in a cluster!! help
If there are 2 route reflectors in a cluster,
does they need to be physicaly connected?
Does fully meshed means that they need to be
physically connected?
Community Member
Re: multiple RR in a cluster!! help
no, they don't have to be phy. conn.
Community Member
Hi.
As you have 2 RR on the same cluster, don't forget to configure the cluster-id on both of them. The cluster clients should connect to all the RRs within the same cluster, in this case they must connect to the 2 RRs.
Hope it helps.
NM
135
