Mysterious Blockage - 2950 & 2900XL Switches
LAN has Switch A (2900XL) connected to Router. Switch B (2950) is connected to Switch A. Both switches only have VLAN1 and each has its own IP address. Network info: 192.168.2.0/255.255.255.0.
Switch A has server 192.168.2.8 and workstation 192.168.2.226 connected.
Switch B has workstations 192.168.2.13, 192.168.2.229, and printer 192.168.2.232 connected.
Cluster management is not enabled; trunk is not enabled between switches.
Symptoms:
192.168.2.13 can not ping or tracert 192.168.2.232 or 192.168.2.229. Can ping and tracert 192.168.2.8 and 192.168.2.226.
192.168.2.229 can not ping or tracert 192.168.2.232 or 192.168.2.13. Can ping and tracert 192.168.2.8 and 192.168.2.226.
192.168.2.8 can ping and tracert everyone.
Switch B can ping everyone but can not trace ip to 192.168.2.232.
Switch A can ping everyone but can not trace ip to 192.168.2.232.
MAC Address table on Switch B is empty.
MAC Address table on Switch A is populated.
This problem didn't used to exist but don't know what changes caused it. Any ideas?
1 ACCEPTED SOLUTION
Re: Mysterious Blockage - 2950 & 2900XL Switches
This looks pretty default. You could try to reload the switch and I would add the following for each access-port:
switchport mode access
spanning-tree portfast
Please let me know if this helps, I will have another look at it tomorrow.
Leo
It looks as if the problem is with switch B.
All misbehaving nodes are on it and it's mac-table definitely should contain some adresses. It may have turned on the private vlan feature or something like that. Could you post the config of switch B?
Leo
Current configuration : 2208 bytes
! Last configuration change at 16:38:55 CST Thu Feb 2 2006
! NVRAM config last updated at 15:59:41 CST Thu Feb 2 2006
version 12.1
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
hostname ScheibMR
enable secret 5
clock timezone CST -6
clock summer-time CDT recurring
ip subnet-zero
interface FastEthernet0/1
description Community
no ip address
interface FastEthernet0/2
description Bea-II (not used)
no ip address
interface FastEthernet0/3
description Carmilita
no ip address
interface FastEthernet0/4
description Jodie
no ip address
interface FastEthernet0/5
description Nurse
no ip address
interface FastEthernet0/6
description Conference
no ip address
interface FastEthernet0/7
description Laura
no ip address
interface FastEthernet0/8
description Darleen
no ip address
interface FastEthernet0/9
description Printer (4100)
no ip address
interface FastEthernet0/10
description Behavior
no ip address
interface FastEthernet0/11
description Bea-I
no ip address
interface FastEthernet0/12
description Brenda
no ip address
interface FastEthernet0/13
description Printer (4000)
no ip address
interface FastEthernet0/14
description Donna
no ip address
interface FastEthernet0/15
description Michele
no ip address
interface FastEthernet0/16
description Susan
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
description Scheib MH Switch
no ip address
interface Vlan1
ip address 192.168.2.3 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.2
ip http server
snmp-server engineID local 800000090300000AF4FABF01
line con 0
line vty 0 4
password
login
line vty 5 15
password
login
ntp clock-period 17179909
ntp server 128.249.1.1
end
Leo
I rebooted the switch and the mac-address-table was instantly populated and the other problems went away. Thanks.
147
