NAT and BGP on same router.
Can you run NAT on the same router that is also running BGP? If so, is the “ip nat outside” statement placed on each serial interface or the loopback? I can’t find any examples on Cisco site.
Dave Tomblin
dtomblin@tsunamicomm.net
Re: NAT and BGP on same router.
NAT and BGP are basically unrelated. You can run them both on the same router.
"ip nat outside" should be placed on any interface that NATed traffic exits your network. Most likely not the loopback unless you're doing "nat on a stick".
Mick.
I tried a configuration on my practice rack where router a and router c had an ebgp session, and router b was between them, and running NAT.
It was successful. I did have to NAT 1 to 1 for the BGP address, and in my example use EBGP multi-hop.
The config’s looked strange. However, I verified that the source address was not imbedded in the BGP packet.
Regards;
Doug Lockwood
167
