NAT and XWINDOWS problem
I have got two UNIX workstations connected by two CISCO 803 ISDN routers. I would like to display from one workstation to another by using XWINDOWS. If I try it without NAT it works fine, but if I use NAT, the XWINDOWS server can't find the client on the other side. There is any way to allow redirect the display from one workstation to another using NAT at the same time?
Worstation A --- CISCO803 A -----ISDN ------ CISCO803 B ----- Workstation B
CISCO803 A: all traffic get out with the same IP address (using NAT)
In Workstation B:
setenv DISPLAY workstationA:0
xclock (application to display time)
Error, can't open display.
In Workstation A: anything happens
Thanks a lot
Bronze
Re: NAT and XWINDOWS problem
I vaguely recall Xwindows uses TCP and UDP port 6000. See if a static NAT entry for the port number makes it to work. Configs from both the 800 routers could also
help us help you.
~Zulfi
Hello, thanks a lot for your help.
This is the configuration router:
Current configuration
version 12.1
no service pad
service password-encryption
hostname prueba
boot buffersize 8056
boot system flash c800-y6-mw.121-2.T.bin
logging buffered 4096 debugging
no logging console
username ......
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Loopback0
ip address 172.24.99.1 255.255.255.0
interface Ethernet0
ip address 10.202.136.39 255.255.224.0
no ip redirects
ip nat inside
no cdp enable
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
no cdp enable
ppp authentication chap
interface Dialer80
description REMOTE ACCESS
ip unnumbered Loopback0
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 300
dialer string XXXXXX
dialer caller XXXXXX
dialer max-call 4096
dialer-group 1
no cdp enable
ip nat translation timeout 120
ip nat inside source list 101 interface Loopback0 overload
no ip http server
ip classless
ip route 10.202.136.0 255.255.255.0 Ethernet0
ip route 192.100.1.0 255.255.255.0 Dialer80
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
no cdp run
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 3
exec-timeout 0 0
password 7
login
line vty 4
no exec-banner
exec-timeout 0 0
password 7
login
rcapi server port 2578
end
The configuration on the other side is symmetric.
Do you mean something as:
ip nat outside source static tcp 172.24.99.1 6000 10.202.136.102 6000
don't you?
Bronze
Yes, thats what I meant. Any luck yet with this?
~Zulfi
Hello Mr. Zulfi,
I tried that, but it doesn't work:
version 12.1
no service pad
hostname routerA
no logging console
username routerB......
ip subnet-zero
no ip domain-lookup
interface Loopback0
interface Ethernet0
no ip redirects
ip nat inside
no cdp enable
interface BRI0
no ip address
encapsulation ppp
no cdp enable
interface Dialer80
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip nat outside source static tcp 172.24.99.1 6000 192.100.1.25 6000
no ip http server
ip classless
no cdp run
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 3
exec-timeout 0 0
password 7
login
line vty 4
no exec-banner
exec-timeout 0 0
password 7
login
end
I telnet from a PC 10.202.136.36 behind of router A to the IP 192.100.1.25 behind of router B.
Router B doesn't use NAT.
Then, from PC 192.100.1.25, I redirect its display to PC10.202.136.36 but when I execute any application using XWIN, PC10.202.136.36 doesn't receive anything. I used two sniffers in both sides and I checked that XWIN traffic goes from PC 192.100.1.25 to 172.24.99.1 but not to PC10.202.136.36 ????
Thanks a lot
Bronze
Juan, I think its about time you open up a case on this issue. Xwindows has this problem as a well known issue in conjunction with NAT/PAT. Generally a static NAT entry makes it to work but I think we are missing something here. This is all due to the complex nature of Xwindows since it embeds IP addresses in payload, which is problematic when it comes to NAT.
~Zulfi
OK, I will try to open up a case.
Thanks a lot anyway.
125
