Webcast-Catalyst9k
NAT help on a 2610
I have a client with a 2610 router which has NAT turned on. He needs to turn NAT off on the 2610 in order that his non Cisco firewall can do the translation function.
Is this just a simple command line input of "no ip nat" on the 2610?
tia
1 REPLY
Silver
Re: NAT help on a 2610
Remove ip nat inside (from inside interface) and ip nat outside (from outside interface). There will/should be some nat pools that you can delete to clean things up but the inside/outside removal should take care of nat all together.
Hope this helps,
Don
101
