NAT Inbound/Outbound Problem
Greetings -
Here is the situation. I have 3 hosts on Private IP behind a 2500 Router. I am using PAT to xlate the 3 Private IP to a single Public IP.
Host1 172.16.99.x1
Host2 172.16.99.x2
Host3 172.16.99.x3
PAT Address 220.xxx.xxx.xx1
The directly connected (T1) vendor has only opened 1 port on their firewall for us to establish TCP connections with their inside host.
Global Commands:
ip nat pool name 220.xxx.xxx.xx1 220.xxx.xxx.xx1 prefix 24
ip nat inside source list 1 pool name overload
access-list 1 permit 172.16.99.xx1
access-list 1 permit 172.16.99.xx2
access-list 1 permit 172.16.99.xx3
Ethernet0
ip nat inside
serial0
ip nat outside
Outbound connections work fine.
Question: If the vendor needs to establish a tcp session with host #2 (Only), is it possible to do so?
And what config changes would we need to make in order to make this happen?
Thanks in advance.
sg
1 REPLY
Re: NAT Inbound/Outbound Problem
if you want to establish a tcp session from the outside to the inside, use the static nat command.
ie:
for an inside webserver.
ip nat inside source static tcp x.x.x.x 80 x.x.x.x 80
use the question mark (?) to see what address to place instead of x.x.x.x (never sure if this is global first or local first)
116
