04-02-2006 12:03 AM - edited 03-03-2019 02:36 AM
is there any facility to configure NAT like this.
two networks having 192.168.1.0/24 address.
I want to translate like this.
192.168.1.0/24 to 192.168.2.0/24
that means 192.168.1.1 becomes 192.168.2.1
and 192.168.1.2 becomes 192.168.2.2 and so on consecutively................
is there any such one-to-one NAT for ranges mapping facility?
skrao
Solved! Go to Solution.
04-02-2006 03:29 AM
Yes, there is such a facility and it's called static network translation. You would configure it as such:
ip nat inside source static network 192.168.1.0 192.168.2.0 /24
With the above config, 192.168.1.1 becomes 192.168.2.1, 192.168.1.2 becomes 192.168.2.2 and so on....
Pls do remember to rate posts.
Paresh
04-02-2006 03:29 AM
Paresh
