NAT problem (DNS being doctored)
I have discovered a feature of NAT which is causing a problem.
The feature was added in 12.2.13(T) for a default inside server so that port translations are not required if connections are to one inside device.
The problem I have discovered is that some apps use DNS to discover the outside address of the NAT device so that they can work properly. What is happening though is the DNS reply is being doctored to the inside address which is causing application problems.
I would like to have this feature enabled but disable the doctoring of DNS records if thats possible.
An example of this is action as follows:
NS Lookup queries:
> host217-34-81-150.in-addr.btopenworld.com
Server: inh2dns08.imsnet2.btopenworld.com
Address: 213.120.62.104
Non-authoritative answer:
Address: 192.168.0.1
Now the debug:
Router(config)#ip nat inside source static 192.168.0.1 interface dialer1
Router(config)#
Feb 14 22:36:53.441: NAT: i: udp (192.168.0.1, 2273) -> (213.120.62.104, 53) [55
939]
Feb 14 22:36:53.441: NAT: s=192.168.0.1->217.34.81.150, d=213.120.62.104 [55939]
Feb 14 22:36:53.477: NAT: o: udp (213.120.62.104, 53) -> (217.34.81.150, 2273) [
31827]
Feb 14 22:36:53.485: NAT: DNS resource record 217.34.81.150 -> 192.168.0.1
And with "no ip nat inside source static 192.168.0.1 interface dialer 1"
Address: 217.34.81.150
Any command to disable the DNS doctoring?
Many thanks in advance.
Re: NAT problem (DNS being doctored)
I am not sure on this but have you tried no ip domain-lookup ?
It's not as simple as that Im afraird, I already have "no ip domain-lookup" as part of my config.
sra
We have more or less the same implementation and, or course, ran into the same problems. We needed that NAT but we also needed the DNS packets unchanged.
The easiest way is to use the no-payload option of the "ip nat inside source static" command. What it does is disable the translation of the DNS payload which is, if I am not mistaken, what you need. This option was introduced with 12.2(4)T so you might have to change your IOS. We tried to use this, but this IOS version crashed my router. You might be luckier ;)
You can find some info about this at the URL below:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087bae.html
Thanks for the reply.
Unfortunately I am running a Cisco 800 router and this feature doesn't seem to have been implemeted.
Cheers anyway.
124
