NAT problem using Ip unnumbered
I have a connection to a VSAT link provider that use to link for carrier the data. An ethernet interface for downlink and a serial link for upload.
Only the ethernet int has an IP address and the serial is Ip unnombered with using the ethernet IP @.
I have a second ethernet interface whcich is connected to my inside network.
When i configure NAT every thing is ok but no user PC can access outside. Here are my configuration
interface FastEthernet0/0
description Downlink VSAT
ip address 195.220.116.50 255.255.255.248
speed 100
full-duplex
interface Serial0/0
description Uplink VSAT
bandwidth 128
ip unnumbered FastEthernet0/0
ip nat outside
no keepalive
ignore-dcd
hold-queue 2 in
hold-queue 150 out
interface FastEthernet1/0
description interface vers sogitel
ip address 192.168.1.2 255.255.255.0
ip nat inside
speed 100
full-duplex
router rip
version 2
passive-interface FastEthernet0/0
passive-interface Serial0/0
network 192.168.1.0
network 195.220.116.0
ip nat inside source list 1 interface Serial0/0 overload
ip nat inside source static tcp 192.168.1.1 80 193.220.116.50 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 1 permit 11.0.0.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
dial-peer cor custom
Thank you for your helps
KTC
1 REPLY
VIP Purple
Re: NAT problem using Ip unnumbered
when you do a ´show ip nat translations´ do you see any of your host PC addresses being translated ? Can you post the output of the ´debug ip nat´ command while a host is trying to access an outside destination ?
Georg Pauwen
174
