Webcast-Catalyst9k
NAT problem
I have a leased line which i am using to connect to the internet using the NAT protocol. i have a pool of three real ip addresses given by my ISP of which two have been given to specific PCs(2 PCs ).
The third has been overloaded for the rest of the PCs. To my surprise only the two PCs are the ones able to browse the internet.
The following is the nat configguration:
Cisco_2611_IT#sh conf
Using 3022 out of 29688 bytes
version 12.0
service config
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco_2611_IT
ip subnet-zero
ip host salima 192.168.112.99
ip host Limbe 192.168.10.26
ip host BlantyrePayPoint 192.168.10.1
ip host MaselemaPayPoint 192.168.10.5
ip host LimbePayPoint 192.168.10.25
ip host Blantyre 192.168.10.2
ip host Zomba 192.168.10.22
ip host Mzuzu 192.168.30.30
ip host mangochi 192.168.30.22
ip host LilongweOldTown 192.168.10.14
ip host LilongweCityCentre 192.168.10.18
ip host Maselema 192.168.10.6
interface Ethernet0/0
ip address 192.168.100.207 255.255.255.0
no ip directed-broadcast
ip nat inside
interface Serial0/0
description Connecting MTL Head Office(Maselema)
bandwidth 64
ip address 192.168.30.6 255.255.255.252
ip nat inside
no ip mroute-cache
interface Ethernet0/1
ip address 192.168.240.1 255.255.255.0
ip nat inside
bridge-group 1
interface Serial0/1
description Connecting Salima Customer Care Centre
ip address 192.168.30.9 255.255.255.252
ip nat inside
no cdp enable
interface Serial1/0
description Connecting Ntcheu CCC
ip address 192.168.40.6 255.255.255.0
ip nat inside
no cdp enable
interface Serial1/1
description Connecting M-Streams
ip address 192.168.10.16 255.255.255.0
ip nat inside
no cdp enable
interface Serial1/2
description Connecting Leland Internet Gateway
ip address 10.10.10.2 255.0.0.0
ip nat outside
no cdp enable
interface Serial1/3
description Connecting Ngabu CCC
ip address 192.168.40.11 255.255.255.0
ip nat inside
no cdp enable
router rip
version 2
no validate-update-source
redistribute connected
network 10.0.0.0
network 62.0.0.0
network 128.1.0.0
network 192.168.10.0
network 192.168.30.0
network 192.168.40.0
network 192.168.100.0
network 192.168.116.0
network 192.168.240.0
neighbor 10.10.10.1
ip nat pool Internet_Access 62.192.143.x 62.192.143.x netmask 255.255.255.252
ip nat inside source list 7 pool Internet_access overload
ip nat inside source static 192.168.100.8 62.192.143.x
ip nat inside source static 192.168.100.10 62.192.143.x
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
access-list 7 permit 192.168.100.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
snmp-server community public RO
bridge 1 protocol dec
banner motd ^C
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line aux 0
line vty 0 4
password xxxx
login
no scheduler allocate
end
In other words both the source static configuration are workink ok.
I tried to swap the ip addresses but still couldnt work
What could be the problem?
Silver
Re: NAT problem
in your statement
I beleive you are only allowing 4 ip addresses it is hard to tell since you have the last octet missing , I think you need to tweak the netmask
Re: NAT problem
' show ip nat translation '
would also be of use and show you what is going on in the NAT table
Re: NAT problem
Hi there,
I think you have to creat two nat ip pools, first for static mapping for host and another for internet browsing and then add the second nat ip pool to nat overload statment.
it may work
With regards
Manish Young
115
