NAT problem
I have a problem with a Cisco 826 router and nat.
Until now, we had the following network:
INTERNET
FLOWPOINT ROUTER : External IP 217.136.183.122
| Internal IP 192.9.100.1
MULTITECH ROUTER : External IP 192.9.100.2
| Internal IP 192.8.100.1
+--- Mail server IP 192.8.100.3
+--- Web/FTP server IP 192.8.100.19
INTERNAL NETWORK
This is working just fine.
We intend to replace the first router (FLOWPIONT wich we rent from our provider)
with the cisco 826.
Our provider has configured it for us and it seemes al just fine, but our servers
can't be reached from the internet anymore.
I guess the problem lies in the combination of the routers
Here is the configuration overview:
+++++ Begin overview +++++
Router#show running-config
Building configuration...
Current configuration : 3929 bytes
version 12.2
no parser cache
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router
logging rate-limit console 10 except errors
enable secret 5 $1$i3.K$0dB.wr5I4XWlo5Va8TL8c/
username Dataction password 7 06255A25594A203007
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip domain-lookup
--More-- !
no ip dhcp-client network-discovery
lcp max-session-starts 0
interface Ethernet0
description *** connected to the LAN ***
ip address 192.9.100.1 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
description *** ADSL Office to Skynet (053810938) ***5
ip address 217.136.183.122 255.255.255.0
ip nat outside
no atm ilmi-keepalive
pvc 0/35
protocol ip 217.136.183.1 broadcast
encapsulation aal5snap
ip nat pool buiten 217.136.183.122 217.136.183.122 netmask 255.255.255.0
--More-- ip nat inside source list 7 pool buiten overload
ip nat inside source static udp 192.9.100.2 53 217.136.183.122 53 extendable
ip nat inside source static tcp 192.9.100.2 53 217.136.183.122 53 extendable
ip nat inside source static tcp 192.9.100.2 220 217.136.183.122 220 extendable
ip nat inside source static tcp 192.9.100.2 143 217.136.183.122 143 extendable
ip nat inside source static tcp 192.9.100.2 110 217.136.183.122 110 extendable
ip nat inside source static tcp 192.9.100.2 25 217.136.183.122 25 extendable
ip nat inside source static tcp 192.9.100.3 21 217.136.183.122 21 extendable
ip nat inside source static tcp 192.9.100.3 20 217.136.183.122 20 extendable
ip nat inside source static tcp 192.9.100.3 80 217.136.183.122 80 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 217.136.183.1
no ip http server
access-list 1 permit 195.238.2.0 0.0.0.255
access-list 1 permit 192.9.100.0 0.0.0.255
--More-- access-list 7 permit 192.9.100.0 0.0.0.255
banner motd ^CCCCCCCC
^C
line con 0
exec-timeout 120 0
stopbits 1
line vty 0 4
access-class 1 in
exec-timeout 0 0
login local
scheduler max-task-time 5000
end
+++++ End Overview +++++
Kind regards
Glenn Volckaert
Re: NAT problem
How many service providers do you have?
As far as I understand it, you are doing two different nattings, stage (1) on the MULTITECH, and then stage 2 is on the 826, am I right?
What is "192.9.100.3" IP address? Where does it reside?
Re: NAT problem
Hi, I'm sorry to reply so late, but I wasn't in the office for a while.
We are using 1 ISP. The 192.9.100.3 address is used by the multitech router in its NAT configuration.
The same configuration is been working for quit a while with an other router, so it should be OK.
Thanks for your reply.
Kind regards
Glenn Volckaert
103
