NAT problem
I am studying NAT configuration and have setup two routers for in/out NAT and redundancy. I want to setup the LAB likes this, if the R1(2509) wan link goes down, the floating route come up and the traffic are route through R2 (3700).
But I have a problem on R1 when the wan link is DOWN. The traffic does’t routes to R2 even the correct route shown in the routing table.
When I ping the remote host (192.168.80.3), R1 just simply reply the icmp directly (it acts as the remote host), but the traffic does’t transmitted to the target host…
If I replaced the R1 with a Cisco 3700 then the fail over working well….
If I removed the “ip nat outside source” statement and access the remote host directly (192.168.60.1), the fail over working too. .
Anyone tell me why the configuration does't work on the 2509 ?
R1 – 2509 12.1(27a)
R2 – 3700 12.3(15)
Here is the configuration of the R1.
interface Loopback1
ip address 192.168.80.2 255.255.255.255
interface Ethernet0
ip address 192.168.50.245 255.255.255.0
ip nat inside
interface Serial0
ip address 192.168.20.166 255.255.255.0
ip nat outside
encapsulation ppp
no ip mroute-cache
ip nat inside source static 192.168.50.147 192.168.80.7
ip nat inside source static 192.168.50.146 192.168.80.6
ip nat outside source static 192.168.60.1 192.168.80.3
ip classless
ip route 192.168.60.1 255.255.255.255 Serial0
ip route 192.168.60.1 255.255.255.255 192.168.50.254 20
ip route 192.168.80.3 255.255.255.255 192.168.60.1
1 REPLY
Re: NAT problem
very strange.... after rebooted the router, it works!
103
