Community Member
NAT-problem!
I have a server with ip 10.2.1.4 in a network 10.2.1.x .
I want to get to that server from another server 10.2.15.2 .
Why is this not working???
This is my config on the 2611xm-gateway:
interface FastEthernet0/0
description InternLAN
ip address 10.2.1.222 255.255.255.0
ip nat inside
speed auto
half-duplex
interface FastEthernet0/1
description ExternalLAN
ip address 10.2.15.1 255.255.255.0
ip nat outside
speed auto
half-duplex
ip nat pool firstpool 10.2.1.222 10.2.1.222 netmask 255.255.255.0
ip nat outside source list 1 pool firstpool
ip classless
ip route 0.0.0.0 0.0.0.0 10.2.1.222
ip http server
access-list 1 permit 10.2.15.2
Hope somebody can help me please!
Kenneth
Bronze
Re: NAT-problem!
why NAT? if you're going to connect to 10.2.1.4 from 10.2.15.2, it needs routing between two subnet which connect to fastethernet0/0 and fastethernet 0/1.
Community Member
Re: NAT-problem!
Could I just make a
ip route 10.2.15.0 0.0.0.0 10.2.1.2 ?
And maybe have a acl like this:
to allow only that host to connect to the server 10.2.1.4 ?
Bronze
Re: NAT-problem!
You don't need any route, just set gateway on each server.
- server 1
ip : 10.2.1.4
mask : 255.255.255.0
gateway : 10.2.1.222
- server 2
ip : 10.2.15.2
gateway : 10.2.15.1
note : don't forget to remove all NAT configuration
Community Member
Re: NAT-problem!
This looks almost too easy ;-)
Thank you very much for these very helpfull answers!
And if I want to just open port tcp 4100 to the 10.2.1.4 from 10.2.15.2, and tcp 3389 both ways I can make this acl:
access-list 1 permit tcp 10.2.15.2 0.0.0.0 10.2.1.4 eq 4100
access-list 1 permit tcp 10.2.15.2 0.0.0.0 10.2.1.4 eq 3389
access-list 1 permit tcp 10.2.15.2 0.0.0.0 10.2.1.4 eq 21
Bronze
Re: NAT-problem!
as I understand please see below :
access-list 101 permit tcp 10.2.15.2 0.0.0.0 10.2.1.4 eq 4100
access-list 101 permit tcp 10.2.15.2 0.0.0.0 10.2.1.4 eq 3389
access-list 101 permit tcp any host 10.2.15.1 eq 23
access-list 101 deny ip any any
access-list 102 permit tcp 10.2.1.4 0.0.0.0 10.2.15.2 eq 3389
access-list 102 permit tcp any host 10.2.1.222 eq 23
access-list 102 deny ip any any
access-group 102 in
access-group 101 in
at this acls ,added permit any hosts to telnet to router at its subnet
Please rate if my answers are helpful
Community Member
Re: NAT-problem!
It looks like this could solve my problem!
But when I cannot use the "access-group"-command. Why? Do I have wrong sw?
router(config-if)#?
Interface configuration commands:
access-expression Build a bridge boolean access expression
arp Set arp type (arpa, probe, snap) or timeout
router#sh ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(1b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 14-Jun-01 20:24 by pwade
Image text-base: 0x80008088, data-base: 0x8097F2AC
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
sara-nat uptime is 21 hours, 34 minutes
System returned to ROM by reload
System image file is "flash:c2600-i-mz.122-1b"
Bronze
Re: NAT-problem!
Hi again,
ip access-group ----- in or out not access-group
Abd Alqader
Community Member
Re: NAT-problem!
Hehe!
Yes, I figured it out. Don't know where my head was :-)
I'll try the config tomorrow. Seems like a good solution.
Thank you so far! I'll let you know if it's working.
Kenneth
Bronze
Re: NAT-problem!
Hi Kenneth,
The following document will help you
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic10
Please rate if it does!
Abd Alqader
257
