Community Member
NAT problems and port 443 for banking on line on a Cisco 2620XM
A user on the LAN (172.16.0.0) is trying to do on-line banking (I'm assuming Https port 443). The user is able to access the internet, but when he enters secure login credentials at the secure website, they eventually timeout. I created 2 access-lists, access-list 7 to use dynamic NAT, to NAT all the users on the LAN side to the one public ip address available (195.122.25.17). Access-list 100 is used to define interesting traffic that will bring up the ISDN BRI 1/2 interface to dial out to the internet/ISP. It is set to permit any traffic (ie during the time range specified). If anyone can spot a problem with the configuration I would appreciate it. I am trying to figure out if it's the router that is stopping the replies coming back.
The Static NAT entry NATs the email server to the same public ip address (ie 195.122.25.17) on port 25 for smtp mail. I'm wondering if the NAT is causing the problem or if the access-lists are conflicting in some way.
The configuration is below:
isdn switch-type basic-net3
interface FastEthernet0/0
ip address 172.16.10.1 255.255.255.0
no ip proxy-arp
ip nat inside
duplex auto
speed auto
no cdp enable
interface BRI1/2
no ip address
encapsulation ppp
dialer pool-member 2
no cdp enable
ppp multilink
interface Dialer2
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 2
dialer idle-timeout 300
dialer string 1890 110 110
dialer hold-queue 10
dialer load-threshold 165 outbound
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname letmeout
ppp chap password letmeout
ip nat inside source list 7 interface Dialer2 overload
ip nat inside source static tcp 172.16.10.2 25 195.122.25.17 25 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer2
no ip http server
ip pim bidir-enable
access-list 7 permit 172.16.0.0 0.0.255.255
access-list 100 permit ip any any time-range WORKINGDAY
dialer-list 1 protocol ip list 100
no cdp run
periodic weekend 9:00 to 17:00
periodic weekdays 8:00 to 19:00
Thanks again,
Gerry
1 REPLY
Bronze
Re: NAT problems and port 443 for banking on line on a Cisco 262
The NAT config looks ok, I would suggest running some debugs to determine why the connection is failing. Create an acl between one of your hosts and the ip address you are trying to connect to. Then run a "debug ip packet 100 detail". You may want to schedule a maintenance window to run the debug so that it does not affect the rest of your network. Be sure to disable fast switching when you run the debug so you can see all the packets.
94
