Bronze
NAT translating Loopbacks and outside interface addresses
I have NAT set up on a 2501 with the ethernet interface ip nat inside and one serial interface ip nat outside. But when I ping from the router or extended using a loopback address it is NAT those too. I thought it should only NAT traffic from the inside interface. Can anyone explain? Heres the config
interface Loopback0
ip address 10.8.0.1 255.255.255.0
interface Loopback1
ip address 10.9.0.1 255.255.255.0
interface Ethernet0
ip address 10.1.0.1 255.255.255.0
ip nat inside
ip wccp web-cache group-listen
ip authentication mode eigrp 2001 md5
ip authentication key-chain eigrp 2001 eigrp-key
interface Serial0
ip address 172.16.0.2 255.255.255.252
ip access-group 102 in
ip access-group 101 out
ip accounting access-violations
ip nat outside
no fair-queue
clockrate 1300000
interface Serial0.2
interface Serial1
no ip address
shutdown
router eigrp 2001
redistribute static
passive-interface Serial0
network 10.1.0.0 0.0.0.255
network 10.8.0.0 0.0.0.255
network 10.9.0.0 0.0.0.255
auto-summary
no eigrp log-neighbor-changes
router bgp 200
bgp log-neighbor-changes
neighbor 10.1.0.2 remote-as 200
ip kerberos source-interface any
ip nat pool internet 128.129.0.1 128.129.0.1 netmask 255.255.255.0
ip nat inside source list 1 pool internet overload
ip nat inside source static 10.6.0.1 128.129.0.246
ip nat inside source static 10.4.0.1 128.129.0.245
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.1
ip http server
access-list 1 permit any
* * * and heres some output....
d2501# clear ip nat trans *
d2501#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
--- 128.129.0.245 10.4.0.1 --- ---
--- 128.129.0.246 10.6.0.1 --- ---
d2501#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/15/16 ms
icmp 128.129.0.1:8947 172.16.0.2:8947 1.1.1.1:8947 1.1.1.1:8947
icmp 128.129.0.1:8948 172.16.0.2:8948 1.1.1.1:8948 1.1.1.1:8948
icmp 128.129.0.1:8949 172.16.0.2:8949 1.1.1.1:8949 1.1.1.1:8949
icmp 128.129.0.1:8950 172.16.0.2:8950 1.1.1.1:8950 1.1.1.1:8950
icmp 128.129.0.1:8951 172.16.0.2:8951 1.1.1.1:8951 1.1.1.1:8951
d2501#ping
Protocol [ip]:
Target IP address: 1.1.1.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.8.0.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/13/16 ms
icmp 128.129.0.1:7425 10.8.0.1:7425 1.1.1.1:7425 1.1.1.1:7425
icmp 128.129.0.1:7426 10.8.0.1:7426 1.1.1.1:7426 1.1.1.1:7426
icmp 128.129.0.1:7427 10.8.0.1:7427 1.1.1.1:7427 1.1.1.1:7427
icmp 128.129.0.1:7428 10.8.0.1:7428 1.1.1.1:7428 1.1.1.1:7428
icmp 128.129.0.1:7429 10.8.0.1:7429 1.1.1.1:7429 1.1.1.1:7429
d2501#
The status shows that e0 is the only inside interface
d2501#sh ip nat stat
Total active translations: 2 (2 static, 0 dynamic; 0 extended)
Outside interfaces:
Serial0
Inside interfaces:
Ethernet0
Hits: 115 Misses: 54
Expired translations: 53
Dynamic mappings:
-- Inside Source
access-list 1 pool internet refcount 0
pool internet: netmask 255.255.255.0
start 128.129.0.1 end 128.129.0.1
type generic, total addresses 1, allocated 0 (0%), misses 0
Re: NAT translating Loopbacks and outside interface addresses
The access-list is the proble. You allow "any". This will NAT all addresses on your private network. Solution: Deny what NOT to NAt and ALloe what to NAT.
Bronze
Thanks for the response but the way I understand it, and have implemented it before, the access-list is only suppossed to be applied to interfaces with IP NAT INSIDE. The loopback does not have that, the serial is configured IP NAT OUTSIDE. I know I can filter out the addresses I don't want but I shouldn't have to if I want to NAT all packets coming in an INSIDE interface and going out an OUTSIDE interface.
110
