Community Member
NAT Translation problems
I have this configuration :
interface FastEthernet0/0
no ip address
ip route-cache flow
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation isl 1
ip address
ip nat inside
ip policy route-map INTERNA
interface FastEthernet0/0.2
encapsulation isl 2
ip address
ip policy route-map SERVER
interface Serial0/0
bandwidth 128
ip unnumbered FastEthernet0/0.2
hold-queue 200 in
hold-queue 200 out
interface FastEthernet0/1
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Serial0/1
no ip address
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username cttmexico password 7 xxxxxxx
ip nat translation timeout never
ip nat translation tcp-timeout never
ip nat translation udp-timeout never
ip nat translation syn-timeout never
ip nat translation icmp-timeout never
ip nat translation port-timeout tcp 80 never
ip nat translation max-entries 21474836
ip nat inside source list 1 interface Dialer1 overload
no ip http server
no ip http secure-server
ip classless
ip route Dialer1
ip route Serial0/0 200
access-list 1 permit
access-list 10 permit
access-list 101 deny ip
access-list 101 permit ip any any
access-list 115 deny ip
access-list 115 permit ip any any
access-list 125 deny ip
access-list 125 permit ip any any
dialer-list 1 protocol ip permit
route-map SERVER permit 10
match ip address 101
set interface Serial0/0
route-map INTERNA permit 10
match ip address 125
set interface Dialer1
every thing was working fine until yesterday, now for example i cant browse, but, and here is the funny stuff, i can ping ?
is this a IOS bug problem?
what ios do you think will solve the problem?
my config is not good?
Re: NAT Translation problems
You are not timing out any translations. Is it possible that enough conversations were dropped that you are near the configured limit? See how many translations are active.
Community Member
If you put the IP address for Google in your web browser can you open it. Do you run a firewall?
Community Member
I am not running any firewall ... i have a direct conecction to internet
