Community Member
NAT trouble with web and smtp
Hi!
I have implemented NAT on my 1605R router but I having some problems..
Since then I can't send outgoing mail with SMTP.
The mailserver belongs to my ISP.
I get a message that the TCP/IP connection was lost when I'm sending a mail. That worked before I implemented NAT. And I also trying to port forwarding web traffic to a machine on the inside.
I get a connection, but no pages displays.
Please look at my config and give me hints whats wrong? Only the password parts are missing from it:
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Tilda
boot system tftp c1600-sy-mz.123-1.bin 192.168.1.5
logging console critical
enable password <----------->
ip subnet-zero
ip name-server 192.71.220.10
ip accounting-threshold 10
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
interface Ethernet0
description connected to EthernetLAN
ip accounting output-packets
ip nat inside
interface Ethernet1
description Internet
no ip address
no ip redirects
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated previous
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username <account + password>
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.21 80 interface Dialer1 80
ip nat inside source static tcp 192.168.1.1 23 interface Dialer1 443
ip nat inside source static tcp 192.168.1.5 25 interface Dialer1 25
ip nat inside source static tcp 192.168.1.5 5900 interface Dialer1 8080
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server enable traps tty
end
Best regards
/Leif
Gold
Re: NAT trouble with web and smtp
At least for mail, I suggest a static nat entry for your inside to outside server address
Are you sure you are getting the same ip address (public ip) negotiated from your ISP ??? If this keeps changing, you might have problems receiving email communications, between outside servers and your internal server. (Even though DNS records will have a static entry). Its better to put a static pubic ip address, instead of specifying the ip address of the dialer interface, which is negotiated each time.
Community Member
No, I don't get the same ip address but it doesn't matter. I don't have a mailserver on my network. The mailserver for pop and smtp are on the Internet.
If thats the case, then you dont need all those static tcp mappings for the NAT. Just a simple nat statement such as,
"ip nat inside source list 1 interface dialer 1 overload" would do the job.
Community Member
How do you mean? Is it really necessary?
Can you give a example?
Community Member
Hi, I suggest you just do a stic nat and ignore the protocol part of it.
i mean the line
is enough and you should remove the other ip nat commands specifying the port and protocols.
cheers.
Community Member
But how do I direct traffic to other hosts on my network without them? Is "ip nat inside source static 192.168.1.5 interface Ethernet 1" enough?
But if I have other hosts?
Community Member
Yes, it worked better! Thank you!
109
