Native IOS not working with Flexwan module
Currently I have a Cat6k running with the following modules
WS-X6k-SUP1A-2GE
WS6248-RJ-45
WS-X6182-2PA (flexwan)
Show version:
IOS (tm) c6sup2_rp Software (c6sup2_rp-DS-M), Version 12.1(4)E3, EARLY DEPLOYMEN
T RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.1(3r)E2, RELEASE SOFTWARE (fc1)
BOOTFLASH: c6sup2_rp Software (c6sup2_rp-DS-M), Version 12.1(4)E3,
cisco Catalyst 6000 (R7000) processor with 114688K/16384K bytes of memory.
I am running IOS for the cat6k sup
c6sup12-ds-mz.121-4.E3
This file is not recongizing the Flexwan module and comes up with the following error
"00:33:38: %SM-SP-4-BADEVENT: Event 'dnld_failed' is invalid for the current statetected at '^' marker.,
-Process= "SCP Download Listen", ipl= 0, pid= 23fig)#^@
e 'disabled': scp_dnld_module 3 : 0"
The software and hardware adviser has said that no Catalyst Native IOS will work on all 3 modules. Is this true ?
The advisor had said that the flexwan module "WS-X6182-2PA=" will work with "5.4(2), 12.1(1)EX" but I cannot download 12.1(1)EX from the CCO. Any ideas guys ?
Re: Native IOS not working with Flexwan module
FlexWAN is supported in Native IOS from release 12.1(5a)E1. Refer to the release notes at
http://cio.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/ol_2310.htm#xtocid9
I suggest 12.1(8b)E11 or 12.(11b)E4 and you can download native IOS from
http://www.cisco.com/cgi-bin/tablebuild.pl/cat6000-sup-ios
You need to use a version of Native IOS that has VIP support, I have deployed a number of systems with FlexWAN with E5 or EX IOS versions and have never had a problem.
137
