Natting Help
I have Cisco 515E , I have not applied natting .
My problem is i have one software which I need to connect to some different location.To connect to that software I've to use static command , which interprets any internal IP going out as external(public IP), I cant waste my Public IP . I wanna know how to go about it.
Raghu
Anonymous
N/A
Re: Natting Help
Hi ,
Can u please help me out ...coz i dont have access to above mentioned page....
Could u please copy the contents or tell me wht exactly I want to do.
Raghu
Re: Natting Help
Hi Raghavendra,
Here are the steps for PIX software versions 5.0.1 and later using ACLs.
1) Define a static address translation for the inside web server to an outside/global address.
static (inside, outside) 175.1.1.254 10.200.1.254
2) Define which hosts can connect on which ports to our web/FTP server.
access-list 101 permit tcp any host 175.1.1.254 eq www
access-list 101 permit tcp host 199.199.199.24 host 175.1.1.254 eq ftp
3) Apply the ACL to the outside interface.
access-group 101 in interface outside
You may also use the link below for your reference.
Using nat, global, static, conduit, and access-list Commands and Port Redirection on PIX
http://www.cisco.com/warp/customer/707/28.html#topic1
Please let me know if this is the information that you need.
Best Regards,
Ansley R. Verzosa
153
