natting problem
hi all,
I enabled natting & DHCP on cisco 1721 router here the problem is out of 16 pc's 2pc's are not working .here i am able ping the websites but i am not getting any webpages here i pasted the cnfiguration please suggest
1 REPLY
Purple
Re: natting problem
The problem is that the NAT pool will not allocate the first (network) and last (broadcast) addresses of the range. Either configure a pool with more addresses or use the following command to use PAT:
ip nat inside source list 10 pool stream overload
Hope that helps - pls rate the post if it does.
Paresh
84
