08-15-2006 04:58 AM - edited 03-03-2019 04:31 AM
hi there,
I was wondering, is it possible to set up NAT/PAT for packets arriving/leaving (after being routed) the same interface , e.g. not going "through" the router ?
I think that this is not possible but I need to be sure... Any help ?
Alex
08-15-2006 05:03 AM
Hi Alex,
That is certainly possible, using an intermediary loopback interface. The feature is called NAT on a stick and described here:
http://www.cisco.com/warp/public/556/nat-on-stick.html
Hope that helps - pls do rate the post if it does.
Paresh
08-15-2006 05:24 AM
08-15-2006 05:06 AM
That is called nat on a stick.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094430.shtml
Once you understand how to do this NAT will never confuse you again.
There may be a newer method with the new NAI interfaces in the latest IOS but I have not had time to test this and have not seen any documentation on using these new nat features for this purpose.
08-15-2006 07:40 AM
Hi there,
Just following that article suggestions, I wonder, if I add ip policy route-map to the interface, will it affect the routing for the other IPs, not specified in that route-map ? in other words, if I add "ip policy route-map" command to the interface - will it affect any existing NAT/non-NAT configuration ?
thanks,
Alex
08-15-2006 09:49 AM
Alex,
If PBR (policy routing) doesn't match any traffic then that traffic isn't routed normally i.e based on your routing table and configuration setup.
Hence, when you do NAT-on-a-stick you would want to only match the traffic, that's to be NATted out the same interface, with a route map and force the traffic to go through loopback (nat outside) interface.
Hope that helps!
Sundar
