Community Member
NATting using the same interface ?
hi there,
I was wondering, is it possible to set up NAT/PAT for packets arriving/leaving (after being routed) the same interface , e.g. not going "through" the router ?
I think that this is not possible but I need to be sure... Any help ?
Alex
Purple
Re: NATting using the same interface ?
Hi Alex,
That is certainly possible, using an intermediary loopback interface. The feature is called NAT on a stick and described here:
http://www.cisco.com/warp/public/556/nat-on-stick.html
Hope that helps - pls do rate the post if it does.
Paresh
Community Member
I've had a look, but I need something like this (attached). Both examples in that article not quite what I need.
Gold
That is called nat on a stick.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094430.shtml
Once you understand how to do this NAT will never confuse you again.
There may be a newer method with the new NAI interfaces in the latest IOS but I have not had time to test this and have not seen any documentation on using these new nat features for this purpose.
Community Member
Hi there,
Just following that article suggestions, I wonder, if I add ip policy route-map to the interface, will it affect the routing for the other IPs, not specified in that route-map ? in other words, if I add "ip policy route-map" command to the interface - will it affect any existing NAT/non-NAT configuration ?
thanks,
Alex
Alex,
If PBR (policy routing) doesn't match any traffic then that traffic isn't routed normally i.e based on your routing table and configuration setup.
Hence, when you do NAT-on-a-stick you would want to only match the traffic, that's to be NATted out the same interface, with a route map and force the traffic to go through loopback (nat outside) interface.
Hope that helps!
Sundar
113
