01-22-2003 07:38 PM - edited 03-02-2019 04:27 AM
I just see this link : http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t8/dtnbarad.htm#1079748
and try to set router to control bandwidth from KaZaA. I used IOS version 12.2.13 on router 7200 and put these setting in configuration:
class-map match-all morpheus
match protocol gnutella file-transfer "*"
class-map match-all kazaa
match protocol fasttrack file-transfer "*"
policy-map inputpacket
class kazaa
police 8000 1000 1000 conform-action transmit exceed-action drop violate-action drop
class morpheus
police 8000 1500 1500 conform-action drop exceed-action drop violate-action drop
interface Serial3/1
service-policy input inputpacket
interface Serial3/2
Anyway, when I show policy-map int s3/1, it doesn't have any packet on that policy:
Class-map: kazaa (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol fasttrack file-transfer "*"
police:
8000 bps, 1000 limit, 1000 extended limit
conformed 0 packets, 0 bytes; action: transmit
exceeded 0 packets, 0 bytes; action: drop
violated 0 packets, 0 bytes; action: drop
conformed 0 bps, exceed 0 bps, violate 0 bps
Class-map: morpheus (match-all)
0 packets, 0 bytes
Match: protocol gnutella file-transfer "*"
police:
8000 bps, 1500 limit, 1500 extended limit
conformed 0 packets, 0 bytes; action: drop
That's mean it cannot block any KAZAA packet. What's wrong with this configuration?
01-24-2003 10:49 AM
I would download the Kazaa2 PDLM file. Once installed, this will give you another option in your "match protocol statement". It will be "match protocol kazaa2"... which will allow you to match on the new kazaa version 2 program.
Please visit the software center for IOS software and go into the PDLM section. http://www.cisco.com/cgi-bin/tablebuild.pl/pdlm Make sure to read the documentation on this new feature as it's very new and you need certain versions of IOS to run it.
This is a NBAR enhancement that was just released and I was having the same problems blocking kazaa until this was installed.
01-25-2003 06:05 PM
Thank you for your suggestion. I just do it following your instuction but it still doesn't work. class-map kazaa2 cannot match any kazaa2 packet and kazaa2 can use. I don't know why.
01-31-2003 01:03 PM
I'm having the same problem with Kazaa2 traffic not being detected even with the kazaa.pdlm loaded. Have you had any luck yet? If so, what might I be missing?
02-11-2003 04:24 PM
Loaded IOS 12.2(13)T1 for my 3640, now it works!
