Need 2 ISDN BRI Channels Active
I have a Cisco 3620 router with an 8 port ISDN BRI module in it. I have one main number that rolls over to a free number when users dial up via ISDN. They connect with one channel fine but the second channel only comes up when they do something large like transfer a file. I would like for the 2 channels to be up constantly. How can I do this? Currently I have this in my Dialer section:
interface Dialer1
description connected to Dial-inPCs(ISDN)
ip unnumbered Ethernet0/0
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 3600 either
dialer load-threshold 10 either
dialer-group 1
peer default ip address pool FRSI3620
no cdp enable
ppp authentication pap chap
ppp multilink
thanks in advance,
Mike
1 REPLY
Re: Need 2 ISDN BRI Channels Active
You can have two b channels come up one after the other by reducing a load threshold. For that you need to use command "dialer load-threshold 1 either" under the interface. With the idle-timeout of 3600 secs, channels will be dropped if they are not passing any interesting traffic for one hour. So you might need to increase that valuue as well using "dialer idle-timeout x" command.
84
